Sequential greddy tt setup?
Old 05-03-2011, 08:57 AM
15lb.test
15lb.test's Avatar
Default Blowoffs set at different levels?
So... Another question about something I have noticed on this car.
When hitting boost, and letting off i have a "double" blowoff sound. When I had the car on the lift, i saw 1 Greddy Wastegate, and 1 Tial Wastegate.. (even thought they are one and the same still seemed wierd) I don't believe that they have anything to do with the woosh sound of releasing pressure Correct? Why would I be hearing a double right side left side whoosh.. ?
I appologize if this is a stupid question and appreciate the insite..
Eric
Old 05-03-2011, 09:03 AM
str8dum1
str8dum1's Avatar
they could quite possibly have different wastegate springs in them. I personally wouldnt run 2 different wastegates. Probably wont hurt anything since its a TT
Old 05-03-2011, 09:05 AM
Vq.turbo.DremZ
Vq.turbo.DremZ's Avatar
Compressor surge?
Old 05-03-2011, 09:23 AM
15lb.test
15lb.test's Avatar
thats what i was thinking.. it shouldn't hurt it though you think?
that is my main concern..
I am finding that it is way cheaper to buy a already built car, but you spend alot of extra time trying to figure things out and fix what others didn't see as issues!
Old 05-03-2011, 09:37 AM
Alberto
Cranky FI Owner
Alberto's Avatar
Who's $hitbox did you buy?
Old 05-03-2011, 10:30 AM
suprasam
suprasam's Avatar
wastegates in greddy systems are restamped tials.
Old 05-03-2011, 11:01 AM
midz350
midz350's Avatar
Old 05-03-2011, 11:08 AM
15lb.test
15lb.test's Avatar
to protect his identity i will call him dude...
not so much a pile as a project..
Old 05-03-2011, 11:47 AM
str8dum1
str8dum1's Avatar
you should be able to pop the wastegate springs out pretty easily. just do that and see what's what
Old 05-03-2011, 12:28 PM
midz350
midz350's Avatar
Eric
Maybe you have two BOV's with different springs?
Old 05-03-2011, 12:46 PM
suprasam
suprasam's Avatar
what, BOV is it? I have the HKSSVQ3 which is multi valved and can make multiple venting sounds depending on boosting and throttle.
Old 05-03-2011, 12:48 PM
15lb.test
15lb.test's Avatar
One question about that..
If i would upgrade from 5lb to 10lb springs would there be any reason i would need to have the car re-tuned? I had a local "tuner" suposedly tell me I would have to and I believe as well as some others that there should be no reason to...
Old 05-10-2011, 05:24 PM
03 Z33 TT
03 Z33 TT's Avatar
I'm also wondering about the blowoff valve. If there was a wastegate issue, it would be more audiable / evident under load, not after letting off the throttle like the OP asked..
I had an HKS SSQV on my old subaru that made a similar two-stage wooshing sound. Each BOV has a different sound to it!
As for the upgraded wastegate springs from 5lb to 10lb.. Whenever you make any major changes to your engine system like upping the boost, you will always have to compensate with more fuel. Your car will not make this change on its own, your fuel and timing maps will need to be adjusted for the added airflow.
...at least that's how my car works = Þ
Old 05-10-2011, 05:53 PM
thawk408
thawk408's Avatar
Surge. Check your BOV. If you change springs, yes it is a good idea to retune it. Your tuner is smart, you are not.
Old 05-10-2011, 05:58 PM
15lb.test
15lb.test's Avatar
The boost would tech. B staying the same.
I just want to get rid of the hesitation I experience
When it is building boost. Boost isover 13 lbs.
I am actually taking the car to maperformance in mpls to have it tuned.... the current tune is not good... hopefully we see a big diff. Plus we don't have 92 octane like it was prev. Tuned on...
Old 05-10-2011, 06:02 PM
15lb.test
15lb.test's Avatar
Does it make you feel good to put someone down that you don't even know? It sure is a good indicator of your maturity level. Thanks for your post it really contributed to the issue.
Old 05-10-2011, 06:04 PM
thawk408
thawk408's Avatar
Anytime.
Old 05-10-2011, 06:13 PM
15lb.test
15lb.test's Avatar
Anytime.
Now that's funny...
Old 05-10-2011, 07:53 PM
binder
binder's Avatar
well, the problem is you would have to retune the boost controller.
Old 05-10-2011, 08:14 PM
15lb.test
15lb.test's Avatar
It's controlled by the utec...
It's not mapped for the hesitation
So why would the controller need to be changed?
Thanks... e
Quick Reply: Sequential greddy tt setup?
