twin turbo
#61
[QUOTE=rh_334;9138643]After saying "Its not Rocket Scientist" twice its obvious you hardly have the mental capacity to post on this forum let alone have a career that supports a very costly FI build. So like i said earlier
[/QUOT
Damn... Dude, It took you while, I thought you ran off crying to yo momma, but obviously you come back to get handled again. Your advice on here is useless and your not Lack of Intelligence doesn't help nobody on here, so if i were you, save your yourself the embarrassment and get out before everybody realizes your a lil girl.
[/QUOT
#63
on
[/QUOT
[/QUOT
#64
on
#66
For a stock block Greddy Kit even purchased off another member will set you back close to $10k no matter which way you split it. You have to consider more then just the kit itself.
You need to factor in things like:
-Heat wrap
-Wiring
-Hose lines
-clutch as mentioned
-gauges
-metal for brackets
-walbro 255 pump at least
-An actual tune, not some flash crap
-Exhaust
-Downpipes
-etc...
This is only a very quick partial list, but certainly things your not thinking about, and this is if you do all your own labor. I built my whole car on stock block the first time and it was just a tad over 10k. Pulled it all apart and built everything, and again did all my own labor, after maching and parts, almost another 10k for just the motor.
Show me where you can have a complete package anywhere in the country twin turbo a stock block for less then 10k? I'm not sure you can even do it right with a ST kit for much less.
$1390 for a rebuild? What about disassembly of the old motor, machining, setting clearances and tolerances, assembly and installation? Have you ever built a real motor or any motor for that matter? Please do not respond with you built a b16 or some crap like this. Machining a motor alone and having the rotating assembly balanced is $1000 easy unless you know someone, some machining gets well into the thousands depending on what is being done.
-Heat wrap
-Wiring
-Hose lines
-gauges
-metal for brackets
-Exhaust
-Downpipes
-etc...
#68
Administrator
What the hell did I miss up in hurr...
#77
