Haltech Update, with CAN Input/Output Expansion Box
#41
^^ Unless there is a bug fix or additional functionality then there is no point really to the upgrade however to make this decision then full disclosure on the bug fixes would help.
Not just a one liner in the change history. It is a shame after a such a long wait that the improvements in 1.10 are only around the CAN devices. Would of been nice to see some additional functionality for owners that do not want to go down the i/o box path.
#42
on
i agree, this thing has been out for how long and all the updates are far apart and don't even effect function so what's the point in updating. Plus i feel like i'm in the dark with details on any changes they make.
#43
^^^ Main Setup - Advanced - Advanced Tab
However when opening a old map (106) on the PC the PID settings are not there. To see them
make a copy of the new 350z base map
import your old map over new base map
You will now see the PID settings.
I assume when upgrading the firmware on the ECU it will also upgrade the map. I haven't had a chance to test though but from memory on the previous versions this is what it did.
PS: Double check the imported values
#46
on
ya, the added i/o box is nice but it costs to add on. We are just talking about simple updates to the haltech itself. It seems like the other platforms are getting some pretty cool firmware upgrades and our platform isn't getting anything like that.
#47
I look at the haltech and it has everything I could ask for and then some, but then again I haven't owned a boosted car before.
Short of Motec it's kind of already the best out there, no? (correct me if I'm wrong on any of these)
Boost control, turbo timer, knock detection, I/O control voltages, water meth support, super slick GUI, full ignition fuel and timing, CAN bus support, dual wideband support, datalogging, pnp harness, great customer support...
I'd ask for more Display (racepak is a bit cheesy looking for a street car imo) options, and a on the fly external tune switch... but you could do that with the external **** thinger set to boost control.
ps spoke with a local former haltech dealer, he agrees with me for the money there isn't anything better than a haltech (at least for the z)
#48
I'm just curious to know what you think is so critical that the Haltech is missing. The only thing I miss a little bit are more compensation maps, but I don't think it's critical. The Haltech may not be perfect, but it is solid. Nothing today beats the Haltech GUI for end user tuning and no other platform has the level of support provided by Dynosty/Hal. I'm not knocking you UpRev/Osiris guys. I own that also and it is very useful and has its place, but it's not in the same class.
We're lucky to have the Haltech as an option. With the I/O box, I will have the Haltech doing everything I wanted it to do. Traction control with timing and boost, failsafes, two boost settings...(still installing btw - fixing a few other maintenance issues first).
#50
rcdash,
i'm still at a loss with the fail safes. For example if I wanted to limit rpm based on fuel pressure how would u set it up. I can see that you can set the input to be fuel pressure which will reference a fuel pressure table but how do you get the ecu to limit rpm if the fuel pressure drops below a certain level?
#53
rcdash,
1. Use one of the analog inputs for fuel pressure. Use one of the digital outputs as a signal to go to the aux rev limiter to engage it. I have my aux rev limiter set to engage in a number of different conditions using diodes in parallel. I have my aux rev limiter set to 2500 rpms. It can serve as my brake torque launch as well as a failsafe.
2. Use the fuel pressure input as an axis for the cylinder fuel trims to set fuel to -100% when fuel pressure is below a certain point. You would have to be careful of interpolation between cells here to avoid a lean condition but I think it would work fine practically speaking.
3. Use a input and output to throw a relay to cut all power to the injectors if fuel pressure drops below a certain point. You'd have to be careful the car doesn't stall but you could set up a condition that turns the output back on if RPM falls below a certain point.
Is this what you were looking for?
Hal, can I use the DPI as analog inputs somehow. I don't have much use for PWM inputs (like for reading cams) and wouldn't mind have 4 more analog inputs so I can get rid of some of my data logging gear. Just wondering... Thanks! EDIT: I found this http://blog.trossenrobotics.com/2011...-with-arduino/ and it's pretty cheap, but not sure it's worth the trouble (adding a box to get rid of another box). It would give 4 more analog input channels though (converting them from 0-5V into a PWM signal) but the software would be expecting something different, so I suspect it would be a no-go.
#54
When using Open Loop Boost control, the wastegate duty cycle can be adjusted with the trim module. With the trim set to minimum, the boost level is restored to standard with the boost solenoid de-activated. As the trim is increased to maximum, the programmed boost from the maps is used to control boost.
When using Closed Loop Boost control, the target boost level is adjusted according to the trim. With the trim set to minimum, the boost target is set to zero boost. Your turbo will then operate off the minimum pressure as defined by the wastegate spring. When set to 100% trim, the boost target will be targeted at 100% of the value programmed in your Target Boost table.
#55
on
map switching and compensation maps would be helpful. I guess the IO box will give compesation maps (can be setup) but multiple maps and map switching would be very nice. In regards to the io box since it has inputs map changes per input (e85 adjustments is what im' wanting) so i don't have to drain the fuel tank and switch maps if i decide to run pumpgas for a long trip.
I get that in theory you can run a compensatino map for that but just doing say 130% fuel if the voltage for the e85 sensor is at a certain level i don't think is an accurate way to do this. Injectors won't be perfect so 130% in one area of the map may be perfect adn it may be lean in another. If it happens to be lean in an area of boost that is bad. I would feel safer having a solid e85 boost tune then pump and there be a way to correlate between them so i know the limits will be safe.
i'm not sure what else is out there but it just seems odd having all these new updates on the others that don't apply to us. I'll have to look through the updates to pick out specific ones that i've wondered about previously.
as far as GUI, this is exactly the reason i haven't switched from the haltech. I like the interface and although there are features of the 128pin proefi i don't think i'll be happy wtih the interface (i downloaded proefi and looked at a base tune). Interface is a huge deal breaker for me since i like to tinker.
#56
just run closed loop on a VE map. gas AFR ratio is the same as E85 on a gas scale (lambda is lambda).
you just need the haltech to be able to correct 30% or more to maintain the appropriate AFR. Dont even need a content sensor for that. Thats how the newest flex fuel vehicles run
