Haltech Update, with CAN Input/Output Expansion Box
Old 09-21-2011, 10:14 AM
Dynosty
Vendor - Former Vendor
Dynosty's Avatar
Default Haltech Update, with CAN Input/Output Expansion Box
After some testing, the new version of Haltech's ECU Manager software is out! It comes with new firmware, 1.10.1 that supports the CAN expansion products, such as the 12 IO box and EGT boxes.
Download Haltech ECU Manager 1.10.2 <a href="http://files.haltech.com/downloads/platinum/ecu_manager_10/haltech_ecu_manager_1_10_2_release.zip">here</a>.
Change log <a href="http://www.haltech.com.au/index.php/ecu-manager-v1-08-x-change-log">here</a>.
The following functions have been added with the CAN expander boxes:
Generic duty output 1 & 2
A/C control
Datalog switch
Nitrous control
Aux fuel pump
Air temp switches
Battery light
Coolant temp switches
MAP sensor switches
RPM switches
TPS switches
Vehicles speed switches
Thermofan switches
Intercooler spray
Knock light
Generic switch output 2
Water injection
Boost trim
Fuel trim
Ignition trim
Fuel pump
Tacho output
Ignition switch input
The following calibrations have been added with the CAN expander boxes:
EGT 1 - 6
Oil temp
Fuel temp
Fuel pressure
Nitrous pressure
Oil pressure
Fuel pressure calibration is now 8 x 1
Fixes
Fixed O2 control PID settings functionality
Fixed Transient Throttle Coolant Temp Corr functionality
CAN IO Boxes in stock! Call 859-230-9027 to order.
HT059900 IO 12 Expander Box - CAN Based 12 Channel - ECU Only $408
HT059902 IO 12 Expander Box - CAN Based 12 Channel inc Plug & Pins $454
HT059904 IO 12 Expander Box - CAN Based 12 Channel inc Flying Lead Harness 8'ft $545
TCA2 - Dual Channel Thermocouple Kit $456
TCA4 - Quad Channel Thermocouple Kit $732
Old 09-21-2011, 02:12 PM
ace32x
ace32x's Avatar
if i had a haltech would definetly grab one of these ! next year
Old 09-21-2011, 04:17 PM
rcdash
rcdash's Avatar
I wonder who got the first retail unit?
Old 09-21-2011, 07:09 PM
TRYNALIVEPRO
TRYNALIVEPRO's Avatar
I want one!!! If only I knew what it actually does...
Old 09-21-2011, 07:48 PM
rcdash
rcdash's Avatar
It adds customizable inputs and outputs to the Haltech ECU (which stock has only 1 customizable output). Specifically with one CAN IO box, you get 4 analog inputs, 4 digital/pulsed inputs, and 4 digital/pulsed outputs.
For example you could define an input that represents an analog 0-5v input and use that as a manual boost controller, or you could read fuel pressure and trigger a relay to cut boost if pressure drops. Also since all axes on Haltech maps are customizable one of your generic inputs could supplant a stock input. For example you can define an analog input as fuel temperature and another as fuel pressure and use those two as axes to affect injector trims. The possibilities are endless.
My primary uses will be to control my exhaust cut outs using the TPS as a digital switch and setting up fail safes to cut boost under certain conditions. I may also switch over my radiator fan control to the Haltech so that the fans kick on if the trans or oil temps climb since those coolers are currently in front of the radiator.
Old 09-21-2011, 08:01 PM
MR RIZK
MR RIZK's Avatar
Cool... thx for the update
What were the issues and or symptoms that were observed
Also in field testing Hal have you noticed any issues with the firmware upgrade from older versions. eg: is there a process we should follow for the upgrade that we shoiuld be aware of?
Old 09-21-2011, 08:24 PM
MI 35th
OGPremierMafia
MI 35th's Avatar
can you use this with a red box?
Old 09-22-2011, 04:43 AM
Dynosty
Dynosty's Avatar
Yes, the update works with the original red box and newer silver box.
Old 09-22-2011, 04:51 AM
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
now if only they could get hold of the fuel level and out it through the unit.....
Old 09-22-2011, 12:12 PM
jerryd87
jerryd87's Avatar
thank god its finally out it seems to have everything i want with a better interface then proefi thinking ill have to grab haltech now
Old 09-22-2011, 12:22 PM
str8dum1
str8dum1's Avatar
cutouts would be hard to control, so cutouts dont have stops. you let go of the switch to stop the motor. it will continue running the motor as long as you have the switch held. unless you can time control the outout, its gonna be tough.
i hope the I/O box does everything its advertised. as long as it adjusts/compenstates your maps based on the inputs, it should be good. no fuel pressure compensation is one of the biggest drawbacks with haltech
Old 09-22-2011, 01:55 PM
rcdash
rcdash's Avatar
I figured out how to do fuel compensation using the injector trims
Also, my QTEC electronic controller just needs a negative ground trigger - that's it - and that's easy. It controls the application of power to the motors
I've played with the software and I really like the way they implemented it. Very intuitive - very cool. More compensation maps would have been nice, but I have every functional requirement I wanted taken care of, I think. I will let you know if it lets me down.
Many thanks to Hal and Dynosty for keeping me updated, answering all my questions and getting me a unit fast!
Old 09-22-2011, 02:00 PM
accordfreak
accordfreak's Avatar
Is there a flex-fuel e85 feature yet like on the pro-efi?
Old 09-23-2011, 03:06 AM
Bigchef66
Bigchef66's Avatar
PM'd
Old 09-23-2011, 04:40 AM
binder
binder's Avatar
You could use the GM sensor and tie it into an input to tell you the quantity of e85 in your tank but haltech doesn't do any map adjusting or switching so until that is implemented it wouldn't be able to adjust for it. or at least from what i know on the subject so far.
edit, i guess you could use that input and make a fuel compensation table from it if you knew exactly how much fuel you need to increase for e85.
Old 09-23-2011, 04:55 AM
Dynosty
Dynosty's Avatar
^ You could use ethanol sensor input as a fuel/ignition/boost trim via the CAN IO Box to accomplish this
Old 09-23-2011, 06:35 AM
binder
binder's Avatar
how hard would it be to calculate how much more fuel on each area of the map it would take using e85? would it be consistent over the entire map....say if you get X volt input from teh sensor saying you have e85 that would add 40% fuel but that would be over the entire map. What if it needs 40% increase in some areas and only 30% in other areas?
That seems do-able but very tricky (at least in my mind). In theory just a straight amount of percentage across the map would work but as i've noticed with my car it never follows logic these days.
Old 09-23-2011, 05:29 PM
dikspiel
Chestons Toilet
dikspiel's Avatar
i have this but no idea what i am going to do with it. =)
Old 09-23-2011, 06:13 PM
midz350
midz350's Avatar
You can wire it, so it Illuminates some pink LEDs when you hit boost. I know you would like that
Old 09-23-2011, 06:17 PM
dikspiel
Chestons Toilet
dikspiel's Avatar
sorry i dont talk to people with stock blocks, move along son.
Quick Reply: Haltech Update, with CAN Input/Output Expansion Box
