Boosted Performance single turbo fabrication - Page 2 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 04-12-2012, 08:50 PM   #21
Ruthless18x
Ruthless18x's Avatar
Awesome work.
Ruthless18x is offline   Reply With Quote
Old 04-14-2012, 10:00 AM   #22
Boosted Performance
Vendor - Former Vendor
Thanks guys, and on that note mid day update:
Since the F.I exhaust uses OEM rubber exhaust hangers I decided that it would be wise to upgrade them. The reason for this is me not wanting any of the exhaust weight on the headers, as they will be taking care of the turbo weight. In order to do that, some poly exhaust hangers are used:
Since the F.I exhaust hanger rods are only welded on one side, it is easy to move them up a bit to get even more clearance using a large wrench:
Really does not take much effort to move these if needed. Although I think they are fine left alone.
With the poly. hangers the exhaust now hangs up high, and does not touch the skid plate. With the OEM hangers the exhaust was resting on the skid plate. Here is the clearance with the poly. hangers:
Working on the down pipe this morning I had to make a cut on something on the car:
The 6mm stud that holds the heat shield is very long, and needed to be trimmed back a bit. About thirty seconds later and we are good to go:
Shortly after that the 3" stainless down pipe was born:
As you can see I am using a flex pipe. This is so that the rest of the exhaust does not move as much with engine twisting under acceleration. I plan on adding a V-band flange on the 3" section of the Y-pipe. This is where the OEM like exhaust to F.I exhaust conversion option will come in to play.
Boosted Performance is offline   Reply With Quote
Old 04-14-2012, 12:52 PM   #23
DaveJackson
DaveJackson's Avatar
Good for you, Sasha. I'm glad that it is going well for you. Everything looks really great!
DaveJackson is offline   Reply With Quote
Old 04-14-2012, 03:08 PM   #24
Boosted Performance
Got the other bank routed to the turbine:
Three bolt flange transition:
So now it is time to hook up the back purge (pump argon gas on the inside of the piping) and weld it all up solid. There is 32 welds all together...and that translates in to a lot of argon gas, filler rod, and time.
After that, I will move on to the wastegates.
Old 04-15-2012, 08:34 PM   #25
Sylvan Lake V35
Looks great
Sylvan Lake V35 is offline   Reply With Quote
Old 04-16-2012, 08:27 PM   #26
Boosted Performance
Small update today...I managed to get all the smaller stuff sorted out. The two main things being oil relocation, and scavenge pump mounting.
Oil filter relocation:
I made a bracket so that it bolts up using the OEM front skid plate bolts, and as you can see it worked out great..simple bolt on.
The oil system will go like so:
From oil filter sandwich plate to oil filter, from oil filter to oil cooler, from oil cooler back to oil filter sandwich plate.
Since the scavenge pump does not need servicing (10,000 hour life) it's final resting place will be behind the fender. Again, just a simple bolt on:
And I did some shopping today as well, $300 later and I have all that is needed for oil cooling, and oil scavenging. -8and for the oil cooler and -6an for the oil scavenge system. As you can see, there is no cheap rubber hose here:
Old 04-16-2012, 08:49 PM   #27
faiz23
FEZZZZZZ
faiz23's Avatar
so much win and **** in this thread...thnx needed that before i pass out for the night
faiz23 is offline   Reply With Quote
Old 04-16-2012, 08:59 PM   #28
Trigo_
Trigo_'s Avatar
great work
Trigo_ is offline   Reply With Quote
Old 04-17-2012, 10:58 AM   #29
redline06
i want this for my HR so bad , i daydream about it lol
redline06 is offline   Reply With Quote
Old 04-18-2012, 11:29 AM   #30
redline06
would this be a better intercooler option for the HR and VHR motors?
Old 04-18-2012, 05:37 PM   #31
padilla03z
Wow ur like super man. Don't know how u found time to make my de kit while making this vq37 kit. Can't wait long enough for precision to send u my turbo lol
padilla03z is offline   Reply With Quote
Old 04-21-2012, 12:03 PM   #32
Boosted Performance
I like it:
Old 04-22-2012, 01:29 PM   #33
Boosted Performance
At this time I am just making duplicates of everything built so far. These items will stay behind for me to copy for future kits.
I was also toying with the idea of having a single waste gate, but that does not look like it will work out. Room under there car is at a premium. I spend some more time with making the charge pipe coming out of the turbo compressor. There will be a bit of a trick to it when a customer installs it, as it has to go in together with the oil relocation plate. Not a big deal, I will make sure the instructions are good with a lot of pictures.
On with some pictures:
Twins (well, almost):
The second set installed
Charge pipe coming from the front:
Going through, you can see that it changed a bit from previous pictures:
New down pipe:
Oil reservoir in place, it allows the oil from the turbo to drain while the car is off. This is a very important part of the oiling system. Because the oil is allowed to drain, it does not sit in the turbo, and leak past the seals. This means no smoking at start-up. With this reservoir, it is as if the turbo is mounted up high in the engine bay.
Weld up close:
Old 04-24-2012, 01:45 PM   #34
Vas_Z33
i was looking at a few 370s the other day.... i. love. this thread..
Vas_Z33 is offline   Reply With Quote
Old 04-24-2012, 07:44 PM   #35
MI 35th
OGPremierMafia
MI 35th's Avatar
Making me want to get a DD 370 now.
MI 35th is offline   Reply With Quote
Old 04-24-2012, 09:01 PM   #36
Boosted Performance
Quote:
Let's get that 700whp build done on the 350z first Don...focus man, focus..
Old 04-24-2012, 09:14 PM   #37
MI 35th
OGPremierMafia
MI 35th's Avatar
I know I Know, I just left Dynosty after having dinner with Hal and his wife. Lets just say after ZDayZ **** is going to get back on track. However, I think trading my Chopper for a new DD may be in order very soon.
Old 04-24-2012, 09:45 PM   #38
Slick 6MT
Amazing work. Welds look insane!
Can't wait to see the numbers!
Slick 6MT is offline   Reply With Quote
Old 04-27-2012, 09:33 AM   #39
Z33Garage
Z33Garage's Avatar
The look, the work, EVERYTHING looks absolutly Great!
( I just have a fear of having expensive stuff on the bottom part of my car)
Alas! this is deadsexy!
Z33Garage is offline   Reply With Quote
Old 04-27-2012, 02:05 PM   #40
Boosted Performance
Thank you.
Turbo and waste gates are the only things under the car. They also sit higher than the aftermarket exhausts I have seen
What you are saying is that you would never put an HKS exhaust (which is more than a turbo and two wastegaes) on your car because you fear ???.
Thread Thread Starter Forum Replies Last Post
Autocross Brake Pads hajwoj Autocross/Road 27 11-01-2015 05:25 PM
My FI friends, im at a loss of whats causing my issues. i turn to you. Colombo Forced Induction 29 10-10-2015 02:31 PM
Tags
2004, 275, 3432020, 350z, 370z, boosted, iphone, kit, mid, mount, my350z, performance, piping, price, single, turbo, turbos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
