Throttle: intermittent issue.
Hey guys,
this problem started not long time ago.
to give u an idea about the car, it's a 5AT modified with SC and built engine and couple of supporting mods.
"sometimes", when i start the car, put it on Drive or Reverse, the car won't accelerate past 1,250rpm, not even when i floor the pedal. When i put it on Neutral or Park, the car revs just fine... i also noticed when this condition happens, the AFR goes rich (for some odd reason).
sometimes, the car goes into this mode for a minute then poff, gone, then drives fine as if the issue wasn't even there.. sometimes it's like this for a whole day or 2.. sometimes it's a whole week or 2 without this issue.
Another thing i've noticed, when cranking, sometimes it starts the engine and throws "TCS OFF" CEL.. but that does is not link it to the issue directly.. i mean, when "TCS OFF" comes on it doesn't mean there won't be any acceleration. it might be related somehow, but it's not a direct cause.
This issue does not throw any codes (DTC), and when i took it to the dealership, they refused to work on it for 2 reasons.. 1 being it a modified car, 2 there are no DTCs.
any ideas? ppl with similar issue?
I'm assuming you checked the electrical connections for the A/F sensors?
I would get the car up on a lift and check the wiring/sensor on the trans that registers what gear you are in. I would also just unplug the TB next time it happens, then plug it back in and see if that fixes it. I had a similar issue with my TB and it was just a bad connection, but the car stayed in limp mode all the time.
nope, and i've read about them.. unbelievably cheap!
Thanks
i wish it was that easy to figure out really. but the whole car needs to be checked to eliminate the possibilities.
thanks for the input guys, any more ideas?
lolwatbro
10-09-2021 04:58 AM
