i want to turbo my z
#41
on
Hey man there's a lot of information on this site on what you should and shouldn't do to your Z. Its either you stay with a N/A car or a F/I car. NA means naturally aspiratted and FI means Forced Induction. If you wanna stay NA you can start with some simple bolt on performance parts to a whole lot more... with that you should defiantly purchase a aftermarket engine management system to get the best out of your parts... If you want to jump in to the deep pool of Supercharging or Turboing your car, I suggest you do a lot and I mean a lot of research... try to understand what they do and how they work... find out what is needed for you to have a turbo car.. It gets extremely expensive and stressful for most people if not all.
I want to turbo my z. I'm looking for some guide lines or somthing to fallow. I'm looking to get just a single turbo but also if I want to drive home to Maine (1000mi) I can. please point me in the right direction. How do you tell the model of the car also no book with it. Says Nismo on the back Nismo shifter and intake also Nismo caps under hood.
#45
on
Well to start i highly recommend this beautiful piece of engineering. It will easily add 300 hp without a tune. You should buy it
http://www.ebay.com/itm/New-Electric...6e0790&vxp=mtr
#46
#47
on
>_<
I'm selling it to some schmuck and then picking this up. Combine it with a tornado, and I should be about even with the horsepower. Then I can afford cams!
#50
get the turbonetics but purchase a precision PT118 cea for it, will bolt right up, your better off with a twin turbo though and two of that turbo since a single is a bit small for a v6. then your gona want to replace the flash turbonetics sends with a split second box from vortec its way better. it will be great for a daily and give you good power for the street.
#51
My ex's bro in law was all geeked one day to show me this retardation he had installed in his civic.
#52
on
#53
Don't go with turbo. It's been over done, it's cheap, and it's too easy. Put a jet engine in it. It doesn't cost much more and you can install it in a weekend if you have a friend. My car makes 1600 horsepower! Trust me, op
#57
Administrator
11 to 1, E-85 build would be cool, I would contact Relentless to set it up using all Nismo engine parts.
