View Poll Results: Greddy Install, pull engine or not
Pull Engine
44
95.65%
Leave In
4.35%
Voters: 46. You may not vote on this poll
Greddy Install...engine in or out?
Old 01-09-2015, 06:25 PM
  #121
Escobar
Escobar's Avatar
couple updated pics for ya. Got some custom oil feed lines made. Really nice fit, got rid of the banjo bolts and all that junk. Got the oil temp sensor tapped into the sandwich plate...last pic is my custom heat shields ceramic painted.
Attached Thumbnails Greddy Install...engine in or out?-img_4819.jpg   Greddy Install...engine in or out?-img_4818.jpg   Greddy Install...engine in or out?-img_4835.jpg   Greddy Install...engine in or out?-img_4836.jpg   Greddy Install...engine in or out?-img_4838.jpg
Old 01-10-2015, 08:24 AM
  #122
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
Great photos!! I have steel braided hoses for my oil scavenge - much better look if nothing more.
what are you going to do about your oil pressure sensor? that was mounted where youre tapping your oil??
If you're gaskets arent installed yet I sprayed mine with copper spray - might be something to consider
I'm still working on that PS fitting/bend mod for you - I do have a second hard pipe which I might photo shop...assuming you still need a little guidance on that?
Old 01-12-2015, 12:33 PM
  #123
Escobar
Escobar's Avatar
There is a bolt above the oil filter that I drilled/tapped for the pressure sensor. I'll snap a pic of it. hopefully there is enough clearance for it. As far as the PS line, the guy welded the pipe coming off the turbo and it looks like it may clear it? I'll have to see once I get it back in the Z. From what ive read most people just bend it out of the way. One issue I see it the driver side turbo charge line. It seems to be hitting the idler puller for the AC compressor. Doesnt seem to be a good fit there, and my oil return line is right there in the way too of course. I put a 90 on it but it still looks tight. Ill snap some more pics. Once I mounted the sandwich plate I had more issues with clearance from the feed lines. I'm going to have to put 90s on them off that T so I can get all those lines to work. Theres alot of stuff going on in that small area.
As far as the spray, I got some of the permatex ultra copper in a tube and put a light film on my gaskets. That should hopefully give me a good seal!
Old 01-12-2015, 05:11 PM
  #124
Escobar
Escobar's Avatar
Default clearance issues
here are my clearance issues. This oil pan return location are tough. Any ideas?
the last pic is where I relocated my oil pressure sensor to (thanks charles)
Attached Thumbnails Greddy Install...engine in or out?-img_4844.jpg   Greddy Install...engine in or out?-img_4845.jpg   Greddy Install...engine in or out?-img_4846.jpg
Old 01-18-2015, 07:32 AM
  #125
bealljk
bealljk's Avatar
Its not great...but you
Old 01-18-2015, 08:27 AM
  #126
Conway_160
Conway_160's Avatar
Looks tight a FCK in there!
Old 01-18-2015, 11:50 AM
  #127
Escobar
Escobar's Avatar
ok, so your more or less just straightening it out, not bending it forward or back. thanks
Old 01-19-2015, 06:12 AM
  #128
bealljk
bealljk's Avatar
Individual results may vary ... big picture is that you gotta fit the intake charge pipe between the pump and that hose connection...so you gotta open it up in some form or fashion.
Old 01-19-2015, 12:21 PM
  #129
Escobar
Escobar's Avatar
got ya. Im sure once I get it back in the engine bay I'll have tons of clearance issues to work out. thanks
Old 01-19-2015, 08:42 PM
  #130
bealljk
bealljk's Avatar
Got a few things done on mine...mocked up the passenger side...
Old 01-20-2015, 12:37 PM
  #131
Escobar
Escobar's Avatar
not much room in there is there?! I cant wait to fight with it
im thinking about removing the ac compressor and all that for added clearance on this pipe...where is this bracket I circled supposed to bolt to? Mine isnt remotely close to anything.
File Type: bmp
Old 01-20-2015, 05:27 PM
  #132
bealljk
bealljk's Avatar
my AC went away - it clears things up very well...I'm tempted to look into a electrical pump driven power steering system...I'd love to clear up the passenger side.
Old 01-20-2015, 06:24 PM
  #133
Escobar
Escobar's Avatar
that would be cool. I rarely use my AC, usually just roll windows down. It gets pretty damn hot here in NC so Im going to try and make it work for the time being.
Old 01-20-2015, 10:31 PM
  #134
bealljk
bealljk's Avatar
I would keep it...my car is stripped and every excess/unnecessary weight is off the car.
Old 01-24-2015, 07:00 PM
  #135
Escobar
Escobar's Avatar
got the engine back in. Once I figured out my passenger side turbo was wayyy off. Clocked it straight up and it went right in. Really not bad at all. Now I have to put everything back together
Old 01-31-2015, 06:19 AM
  #136
Escobar
Escobar's Avatar
couple pics of the progress. what a nightmare to get these pipes in on the passenger side. In the last 2 pics, I have 2 nuts jb welded to the pipe. Was that for nos or meth injection?? If you click on them they should rotate.
Attached Thumbnails Greddy Install...engine in or out?-img_4923.jpg   Greddy Install...engine in or out?-img_4924.jpg   Greddy Install...engine in or out?-img_4926.jpg   Greddy Install...engine in or out?-img_4925.jpg
Old 01-31-2015, 10:40 PM
  #137
bealljk
bealljk's Avatar
yeah - pain in the nuggets...I'd love to eliminate my PS pump ... not sure what those JB welded nuts are but I would just plug them.
Old 02-01-2015, 04:03 AM
  #138
Cux350z
hatersgonnahate
Cux350z's Avatar
Theres a tab on the front of your upper oil pan that it lines up with. Its the flat one with the sharpie mark.
This pipe should connect to a small cast pipe that then connects to the driver side turbo outlet.
Plug those holes, it was most likely for meth injection. You may be able to use one for the boost ref to the wastegate since it is pre-throttle body.
Old 02-01-2015, 07:00 AM
  #139
Escobar
Escobar's Avatar
thanks cux, my pipe wasnt close enough to mount to that, I just made my own bracket for it. If I used that tab the pipe would hit the pulley. I just got some bolts and plugged those holes...I also ordered new filters to replace my mushroom of death filters. Went with the aem dry flow
Old 02-01-2015, 10:27 AM
  #140
Cux350z
hatersgonnahate
Cux350z's Avatar
Those tabs should line up. Maybe clock your inducer housing and massage the pipes.
Quick Reply: Greddy Install...engine in or out?
