JWT 700BB Engine Build Results - Page 3 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 11-08-2012, 09:25 AM   #41
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Quote:
Originally Posted by djamps View Post
^^ that N/A tune was pretty wild.
That is completely stock from Nissan. No N/A tune, no K&N filter, no exhaust. 100% showroom, dealership stock. LOL
Robert_K is offline   Reply With Quote
Old 11-08-2012, 10:58 AM   #42
Voboy
Voboy's Avatar
Quote:
Originally Posted by Robert_K View Post
You're use to reading those big *** turbos than. LOL The GT28's aren't that big. 16-18psi is full efficiency for them. Any more and you start overusing the turbo and lose power. Think with a higher compression and smaller cam they'd spool a bit quicker but I like how the power is almost N/A powerband. I think this will be a fun street car. Take ya for a ride and tell me you're not impressed. LOL
I might take you up on that offer if I ever attend a future Z meet up. You're a crazy SOB for running R888's on the street (and on HRE 19's no less)! :P
Voboy is offline   Reply With Quote
Old 11-08-2012, 12:23 PM   #43
wannabuy350z
wannabuy350z's Avatar
Thanks! How much did the meth kit help you?
i didnt fully take advantage of the meth, as my psi at higher rpms is only 16psi. but its more of a piece of mind and helps keep intake temps low, and about 7% or so less injector duty cycle.
wannabuy350z is offline   Reply With Quote
Old 11-08-2012, 05:16 PM   #44
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Quote:
LOL Well if you come out let me know. And why am I crazy for running R888's on the street on my HRE's?
Quote:
OK. Thanks for the input. I've been tossed up on getting a meth kit or not. I've seen some great results on LS based cars and of course the Mitsu/Subie AWD cars running high boost (25-30+). Guess I'll save the cash though.
Old 11-08-2012, 06:33 PM   #45
Resolute
Resolute's Avatar
Very nicely done Robert, it all looks great!
Will
Resolute is offline   Reply With Quote
Old 11-08-2012, 07:55 PM   #46
binder
Just that it loses steam after 5k RPM. I would want it to keep climbing until redline, but its probably since boost isn't holding and the cams as someone mentioned before. But of course you're still over the 500HP mark so it's nothing to snicker about lol.
It doesn't loose much steam. From 5000 rpm at peak of 550hp it only drops to 520 at redline. That's not much drop for turbos that are maxed out. Tq always drops as it is inverse to RPM.
Nice work robert! You'll love the car. I'm not sure putting meth or anything else on it will be worth the money for its return. At that point you will have to start running drag slicks and all to keep traction so the fun factor starts to taper off.
binder is offline   Reply With Quote
Old 11-08-2012, 07:59 PM   #47
Alberto
Cranky FI Owner
Alberto's Avatar
Congrats man. Solid pump gas numbers.
I'm assuming the f@ggot complaint about the power curve has an NA Z. Fawking jokers.
Alberto is offline   Reply With Quote
Old 11-08-2012, 10:26 PM   #48
wannabuy350z
^lol true...
Old 11-08-2012, 10:27 PM   #49
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Quote:
Will
Thanks Will! Hope you've been doing good!
Thanks Binder. Yeah I looked at the GT28's efficiency map and figured out 16-18psi was full efficiency. Why there is no reason to run more boost. I think with a bit higher compression and maybe a smaller cam the power would move left a little. But none-the-less this should be a fun car to drive on the street or track (road and drag).
Was tossed up with the meth kit. I'm gonna hold off though. Maybe in the far future due to Houston summer heat, but not right now. As far as DR tires I'm already running 305 Toyo R888 tires.
Thank Alberto. I'm looking forward to seeing how the Shell URT 100 helps.
Old 11-09-2012, 05:21 AM   #50
djamps
djamps's Avatar
Goes to show that even on a bone stock VQ a tune is by far the best bang for buck.
djamps is offline   Reply With Quote
Old 11-09-2012, 06:10 AM   #51
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Well back in the day all we had was the UTEC. LOL Now with UpRev I'll agree with you.
Old 11-09-2012, 07:13 AM   #52
binder
Nice choice on tires. A great alignment will be the biggest issue. Get that neg camber down as far as possible. The furthest I could get mine was -1.2. I wanted to get it down under -1 but it started throwing my toe way off. With 650 the mickey thompson 305's still didn't hold very well on the street but it is what it is.
As for the higher octane and meth. If you do anything i would say get an injection kit and just run water injection. That won't require a re-tune and will make your power more consistent in the heat.
Old 11-09-2012, 07:24 AM   #53
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Thanks for the input! Really appreciate it! As far my alignment I don't know the specs. Being in Iraq it's hard to communicate a lot of info. I told PowerFab that I wanted a "squared" set-up. I want the most tire patch and not the crazy camber ****.
We're doing the Shell URT100 for dyno numbers. Don't think I'll be running it that often. But who knows. I haven't research water injection for the VQ. Thanks for the tip!
Old 11-09-2012, 07:57 AM   #54
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Hey I stand corrected. Just talked to PowerFab and they are going to use Shell URT Advance for the race gas tune. Unsure if they will mix or not. Forgot to ask.
Old 11-09-2012, 11:56 AM   #55
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Old 11-09-2012, 02:12 PM   #56
CRIDDA
CRIDDA's Avatar
Robert, next time I am come to Texas, I want a ride. Hell maybe even a drive(I haz great insurance)
CRIDDA is offline   Reply With Quote
Old 11-09-2012, 04:55 PM   #57
Robert_K
Didn't Go Cheap
Robert_K's Avatar
LOL
Old 11-11-2012, 01:39 AM   #58
jomamahama
congrats! thanks for taking risks in iraq as well as taking risks on your car!
jomamahama is offline   Reply With Quote
Old 11-12-2012, 04:59 AM   #59
Robert_K
Didn't Go Cheap
Robert_K's Avatar
Thanks!
Old 11-12-2012, 11:17 AM   #60
ace32x
ace32x's Avatar
Thanks!
solid numbers! we need to race now :P drive up here to washington lol
ace32x is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
JMS Racing Twin Turbo VQ35HR MM'08_350Z VQ35HR 225 03-08-2017 03:50 PM
Al's 400rwhp, Stardast Flared, Shaved Bay, Bagged Z Build Thread 350Z_Al Exterior & Interior 126 03-04-2017 05:22 AM
Engine Stalls if not given a little gas on startup liqalu04 Engine & Drivetrain 12 02-24-2017 08:38 PM
FS: AMS Aluminum Crank Pulley Fixxxercask Engine 6 11-09-2015 11:10 AM
Tags
350z, 700, 700bb, activities, build, building, engine, jwt, kit, powered, spring, team, tt, vbulletin, whp, wit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
