greddy twin build...
Old 10-05-2016, 01:01 AM
  #221
OldManZ350
OldManZ350's Avatar
What Model 350z do you have?
Originally Posted by bealljk
Had the car out yesterday and other than some weird fuel sounds in my lines (swirls and suction sounds - may be cavitation...) the car ran 'fun' ... did a few pulls and got into a new load column to tune...it was fun...
Got up this morning and headed over to the trusty moving & storage facility...they got a .01 ton truck scale, $10 later I came in at 3080 lbs... I did have my computer/book case (enter weight) in the trunk I should deduct...
Photo opp...
Old 10-05-2016, 03:25 PM
  #222
C1Forged
Vendor - Former Vendor
C1Forged's Avatar
This is one insane build. If only I knew how to weld so I could custom fab work to my own vehicles... One day I'll be as cool as you.
Old 10-05-2016, 06:57 PM
  #223
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
'03 touring
thank you - a few hundred dollars, a used miller suitcase welder, and a pile of scrap steel...hardly cool...
Old 10-05-2016, 10:18 PM
  #224
C1Forged
C1Forged's Avatar
Not bad at all for a low budget setup and scraps. Bravo
Old 10-08-2016, 11:05 PM
  #225
bealljk
bealljk's Avatar
Got the passenger side blower off ... As best I can tell the oil line is clogged as well but the blower is still intact with minimal play in the shaft.
I'm leaning towards replacing both with new CHRA along with installing the aforementioned -4 AN lines, an inline filter, and running a thinner oil (currently running 5w valvoline synpower) opinions on oil anyone?
while the car is up in the air:
1. gonna get the first few ducts off the blower welded on (as opposed to using the couplers)
2. reverse my hardware on my oil return lines - fittings on the inside of the pan, nuts on the outside of the pan)
3. install the greddy wastegate relocation kit - Hat tip to Cux350 for pointing me to Total D who fabs them up... (Sucker Punching Motorsports)...
4. get the boost control solenoid fab'd up ... thinking about running hard copper line versus silicone / rubber hose
Old 10-11-2016, 07:57 PM
  #226
bealljk
bealljk's Avatar
inline filter came in ... (bigger than I expected) ... need some -4 to -8 reducers ...
Old 10-29-2016, 02:36 PM
  #227
bealljk
bealljk's Avatar
waste gate relocation kit came in... tip of the hat to Jeremiah @ Sucker Punch Motorspots - I was pretty happy that he fabricates them up! Beautiful welds ...
Old 10-29-2016, 04:42 PM
  #228
Escobar
Escobar's Avatar
very nice pieces there!
Old 11-03-2016, 08:01 PM
  #229
bealljk
bealljk's Avatar
^thanks Esco! I think I'm going to have little bit of a fitment issue on the passenger side ... If I remember right you had some issues with your SVR Tech kit??
I think a 1/2" spacer will fix the problem - I may ask Jeremiah to weld on a stub of pipe and he'll probably modify his jig while he's at it. But all in all, pretty happy with the kit...I knew there may be a fitment issue.
a few things came in...
-4 to -10 fittings came in for the oil filter ... (unintentionally large - didnt realize when I purchased it but gonna roll with it) fab'd up the feed lines.
The diaphragms came in, lube'd up the valve stem with antiseize and bolted everything back together - was careful not to pinch the diaphragm.
Old 11-08-2016, 06:53 PM
  #230
bealljk
bealljk's Avatar
attended a professional public works conference and picked up 6 of these light-bulb shaped squeeze-stress-relievers ... ditch the (clean) shop rags for these:
wastegate relocation going well...
Old 11-13-2016, 10:25 AM
  #231
bealljk
bealljk's Avatar
Building the waste gate assembly ...
If I knew then what I knew now...would have NEVER used the typical nut & bolt setup but rather used hex-head allen wrench bolts...would have solved all my clearance issues and made disassembling so much easier...onward and upward!
I had standard AN -3 hoses to from my vac block to the waste gate and decided to run hard lines ... I was going to order some steel lines but I can pickup copper lines from the hardware store pretty easy... throw some flares on them and I'm good to go...one from the vac block to the solenoid and two from the solenoid to each waste gate.
Old 11-13-2016, 04:30 PM
  #232
Cux350z
hatersgonnahate
Cux350z's Avatar
love this haha
always thought about doing braided AN steel lines for my vac. Had one of my rubber ones get burned on my driver manifold. Coulda been bad!
Old 11-19-2016, 08:38 PM
  #233
bealljk
bealljk's Avatar
ahhh damm!t ... chalk this up to you get what you paid for...found a fabricator thought he would have TIG'd it but I think he squirt-gun MIG'd it...$80 later
but nothing the happy-wheel cant put a shine on...
all in all - happy with how it came out after the 30 minutes of grinding
wrapped up the relocation kit, waste gates installed, hardlines run ...
Old 11-21-2016, 03:21 AM
  #234
tcode
tcode's Avatar
James, looks good outside now. But I would be rather worried about the welds from inside.
Old 11-21-2016, 02:01 PM
  #235
TT03Z
TT03Z's Avatar
Looks good cleaned up but personally I would have left the welds alone. Adds strength and with welding cast aluminum there is a large chance of pin holes. I want to do the same thing with my twin setup. I hate the coupler being so close to heat and its a huge pita to get to the clamps.
Old 11-21-2016, 03:43 PM
  #236
bealljk
bealljk's Avatar
Thanks man! A very good valid concern...especially if something were to break-loose...I'll investigate further...
I hear ya...not too worried about it's strength as long as it stays in one piece. I really wanted to lose those couplers...especially the passenger side right next to the header.
I was very worried about pin holes before I ground off the welds off but nothing was apparent - if I find any I'll have them re-welded...
Old 12-03-2016, 10:39 PM
  #237
nizmo_0385
nizmo_0385's Avatar
dude your W brace is beautiful please mass produce
Old 12-04-2016, 12:09 PM
  #238
bealljk
bealljk's Avatar
^thanks - we had a good 10 to 15 hours of fab / welding time in it ... we collectively fabricated everything to mimic the OEM W brace and a buddy did the welding. It's maybe a pound or two lighter than the OEM steel but nothing significant.
doing away with the copper vac lines ... they arent holding up like I thought they would...back to the AN-3 lines...
boost control solenoid hooked up & plumbed to the waste gates and vac block...
replacement CHRAs/blowers ordered last week - should be in this upcoming Friday...waiting on a few fittings between the turbos and the oil feed lines ...
Old 12-04-2016, 04:12 PM
  #239
Escobar
Escobar's Avatar
nice to see your still working on this and making progress. I did have issues with fitting those svrtech wastegate relocation pipes. I could never get them to fit right with my down pipes. Ended up just having a whole exhaust system custom made. Best decision for sure. Everything fits perfectly. keep up the good work sir
Old 12-05-2016, 12:59 PM
  #240
OldManZ350
OldManZ350's Avatar
-4 Fuel Feed is very small...... hummmmm
Mine is a -8 Feed, then Tee's to two -6's
Quick Reply: greddy twin build...
