greddy twin build... - Page 4 - MY350Z.COM Forums
Thread Tools Search this Thread
Old 06-20-2013, 07:59 PM   #61
bealljk
Quote:
Originally Posted by str8dum1 View Post
just cut a hole in the sheet metal?
were you talking about this?
not sure how I feel about the extra coupler added to the charge side of the IC , I think the blue greddy couplers are played-out but welding a few joints can be done down the road.
bealljk is offline   Reply With Quote
Old 06-22-2013, 10:55 AM   #62
bealljk
made a bracket for the power steering cooler…came out alright but I may have to lower it if I want it in the passive air stream…shouldnt be hard to modify the attaching sheet metal…
doing something similar on the drivers side for the oil cooler…a little more fab work to avoid the IC charge pipe…
OEM thermostat housing and discharge pipe are at the shop have the AN20 bungs welded on and I guess they werent busy bc my contact said he'd have them done this afternoon.
Also bought the proper hardware to mount the IC, radiator and oil cooler…it's crazy hot outside and the garage is a greenhouse so I wont do any work until it cools down later today…instead - I'm gonna drink & drive…
yes, I'm still on Forza 2, about 85% complete with the game...
Old 06-22-2013, 02:21 PM   #63
bealljk
got the coolant pipes back…They look good and I can tackle the radiator setup!
Old 06-23-2013, 08:57 AM   #64
str8dum1
you shoulda had them cut and weld up the oil warmer lines as at the same time
str8dum1 is offline   Reply With Quote
Old 06-23-2013, 05:55 PM   #65
bealljk
Yeah, you gotta point … Wasnt sure how the cooler was going to be situated when I had that work done. My default plan was to hang in between the maybe I can have a similar aluminum angle welded on the other end…it would really help with running the hose back to the sandwich plate.
Got my AN20 hose trimmed to size for the thermo-housing and coolant pipe…
First time in 6 months that the car has been off the lift…I love how low the radiator and IC sit…
going to attempt to wrap my (headers) o2 sensor, not a big task but I'll have to remove the pins from the harness to fit…I have a few rolls of thermo-wrap coming and want to wrap a few things before I re-fluid and turn the key...
Old 06-23-2013, 08:16 PM   #66
herrschaft
Pics aren't working
herrschaft is offline   Reply With Quote
Old 06-23-2013, 08:38 PM   #67
bealljk
relinked, thank you…
any help on this would be appreciated -
http://my350z.com/forum/maintenance-...lors-help.html
Old 06-25-2013, 07:35 AM   #68
Nismo350z#0310
Nismo350z#0310's Avatar
I would polish all the pipping before install! Function is over form, but still gotta have a little form!
Nismo350z#0310 is offline   Reply With Quote
Old 06-26-2013, 11:01 AM   #69
bealljk
Quote:
I agree with you here - most this car is function(go) and very little form(show) but probably not gonna happen…would look out of place…nothing else is polished in the engine bay, my welding isnt art and ultimately a portion of that piping will be covered with reflective wrap...
Old 06-26-2013, 04:02 PM   #70
boostedmaxima
boostedmaxima's Avatar
Quote:
Hmm, I'm not sure if you have enough speakers up front..
boostedmaxima is offline   Reply With Quote
Old 06-26-2013, 06:32 PM   #71
bealljk
Quote:
ha…only half the pic…
I also have 2 in the rear aswell, a cc3 center, 8" and 10" velodyne woofers running off a onkyo rec'v……I collect them ovi 3s, I love them...
Old 07-19-2013, 08:36 PM   #72
bealljk
back on it…reflective heat wrap came in and I started wrapping pipes.
got the passenger side bank complete, still need to put the coolant pipe back on but that's not too bad. Felt like I had to remove hours worth of work to get the intake pipe on... The driver side should be incredibly easy considering my AC comp is gone.
Hoping to make progress this weekend...
Old 07-19-2013, 08:52 PM   #73
Resmarted
[/URL]
the way I have my piping done, and how I recommend yours as mine is almost identical on the driver side is cut where you have that weld, and weld the rest of the piping to the intercooler (leave a coupler connecting it to the fmic). We found this makes it easy to put together/take apart, but reduces the couplers needed.
Resmarted is offline   Reply With Quote
Old 07-20-2013, 08:09 AM   #74
bealljk
Quote:
thanks & great comment - I intend to - I do not like the amount of couplers in that area and the fewer the better imo.
Old 07-27-2013, 09:43 AM   #75
bealljk
Finished wrapping the coolant pipes and the fuel lines. Strung a new fan belt and spent about an hour last night just looking over, checking/torquing down bolts/hose clamps, reviewed my 'dont forget list', modified/ran a few pneumatic lines for the system and bov/WG. Did a quick volume check on my oil coolers and as it sits I have an additional 25-30 ounces of capacity in the 2 coolers. I did pick up another cooler that would add another 10 ounces but I'm not sure if I'm going to add it.
Will put the front end together today/tonight.
Fluids tomorrow or next week…
Old 07-28-2013, 08:46 PM   #76
bealljk
making steps…got the radiator and oil coolers hooked and half the lines where I want them. going to be busy this week so I doubt I will be back on it until next weekend.
Old 07-29-2013, 11:30 AM   #77
Z33Garage
Z33Garage's Avatar
so awesome!
Z33Garage is offline   Reply With Quote
Old 08-01-2013, 07:59 PM   #78
bealljk
started fluids tonight…got the feed lines and oil cooler #1 done…hoping for no leaks
Old 08-12-2013, 07:54 PM   #79
bealljk
Fluids went well - nothing scary happened…I have one small leak from my make-shift over flow tank where it's not sealing up…but I'll cross that bridge when I get there.
Started over the weekend and wrapped it up tonight getting the test pipes on and bolted down…nothing special but had a busy weekend so I couldnt dedicate too much time to it.
today I ran around and found new crush washers for the waste gates and needed a vacuum tee to splice the waste gates into my existing vacuum line. I think once I get my boost solenoid I will be upgrading to the brass tees…I don't have much faith in these plastic ones...
Old 08-13-2013, 06:23 AM   #80
ksuberk54
Nearly a 7 month project. You have more patience than I do. Interested to see how this turns out. Good luck.
ksuberk54 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
~Greddy Revolution Exhaust 03-08 350Z $1165 SHIPPED!!!~ sales@czp Engine 31 12-21-2016 09:32 AM
Finally boosting the z gc350z03 Forced Induction 114 10-28-2016 05:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
