BUDGET Turbo Project- Started
#164
on
Can you please provide updates pictures videos etc. can you write up a list of things bought with prices. What did you have to change or modify on the kit. This would be very informative. Thank you.
#166
I'll update sunday night
#169
on
All combinations of two are true. Cheap and reliable = leave it alone, ie stock. It is cheap (free) and reliable. Other interpretations are simple bolt on modifications such as test pipes, HFC's, intake, exhaust etc, not that expensive (compared to a full engine build at least) and reasonably reliable ie your engine wont throw a rod through the block. None of these things are going to make your car seriously fast however.
#170
Sealed exhaust with furnace cement. First startup there was a leak, but I went under and sealed it.
Got to drive the car and I am not a fan of the stock exhaust. I can barely hear it and mostly I just hear the intake. I was used to my injen which had a very nice sound to it.
I have a really bad boost gauge and I didn't have a power inverted set up for my laptop which doesn't hold a charge. So the boost gauge read between 3-5psi so I'm not really sure how much I'm actually running since the spring wasn't marked in any way.
The banjo bolt on the oil feed was leaking on the turbo before the initial run and I tried to tighten it up and it stripped(I had a spare oil feed fitting, but it's no 90 degrees so it's not the best fit, but it works for now). The smoke from the run was from the exhaust wrap being coated with oil.
The BOV sucks. Well it work's but it's not loud enough, so I'm going to buy a RFL bov since I do not like a sleeper sound.
Total Cost
Godspeed kit/Utec $1440
Oil Pan Spacer $130
550cc Drop in Injectors $180
Stock exhaust free
New Walbro 255 Free(not installed and the car is actually running 12ish afr in boost so i'm not sure if I even need it with the power I'm shooting for)
Misc clamps/bolts/new wastegate(only because I wanted to run lower boost) $100
MAF $20 since I didn't have the housing
$60 oil/filter
Sandwich plate $30
Total cost about 2k
Total Cost
Oil Pan Spacer $130
Stock exhaust free
$60 oil/filter
Sandwich plate $30
Total cost about 2k
#171
OGPremierMafia
on
Good luck and I am glad you managed to finish this project. Although in some aspects its a road guide on things to & not to do as well as things to look out for.
#173
Bought a RFL BOV today(obviously a replica) I will be making a custom plate to converet the Type RS flange to the Type H flange since I don't want to cut up any more of the intake piping and add more couplers.
I also need my wideband sensor cable to hook up to my laptop so I can fine tune.
Also ordered a new electronic boost gauge because the analog one I bought doens't seem to work too well and the gauge doesn't stant still at 0 when the car is off even after taking it apart twice to re-adjust.
Once I get there in I am going to make sure I'm boosting around 5psi becuase I think I'm closer to 4 right now with the wastegate spring. I have about 5 springs though, but I just wasn't sure which one was which
#174
on
Get prosport gauges thats what i'll be running. I like everything so far except for the furnace cement it looks hideous and tacky. Also 99.9% of the people in this thread posting and asking for updates just want your build to fail or blow up so they can make fun of you and say i told you so etc. Just keep the boost levels low monitor your A/F ratios constantly and get that thing professionally tuned oh and invest in a quality meth injection kit and you'll be good for a long **** time. Have fun with it dude.
#175
No one can see the cement. It's under the car and most of it is in hard to reach/see places. I honestly don't care what it looks like as long as it sealed the exhaust leaks(which it did FTW)
I will be tuning myself. The base tune for TN kit with 550cc injectors UTEC tune works very good as a base tune. Once I get that settled I will be taking it to the track and possibly a dyno(eventhough I think the track is a better way of showing the cars power)
Just waiting on my cable and for it to stop raining/snowing so I can log some files
#177
alot of us are indeed waiting for it to blow up, and not a single thing you listen helps protect against unbalanced chra's or crap bearings which is what causes most of these ebay kits to fail especially the godspeed.
