Vortech V3 on 03' 350Z
#42
While snow is on the ground it's good time for projects like Headlight mods I took my CCFL tubes out and put new controllable LED circuits in. Here is the result
Also my blower came back from Vortech. They changed my impeller and valute, also inspected and replaced oil drain line. Very pleased.
SI blower
SI blower
#48
I made DIY because the kit has no installation guide, and i couldn't find it on this forum.
https://my350z.com/forum/engine-driv...l#post10736382
gtzero (11-28-2021)
#55
I see. I plan on using 100% methanol with the 3.33 and Fluidampr Crank. I dont want that much power maybe 480whp. Since you got 16psi from the 3.12 and Fluidampr i may get 14 with the 3.33. Once again congrats! Bet its a blast to drive.
#57
E85
Went to the Zdayz, run on Airstrip Top Dawg event successfully Came back home and went back to RTTuning to do E85 tune. I have a gas station with E85 next to my house so mainly will be running on E85 and switch to the pump gas on a long trips like Zdayz.
Results are not too crazy. We gain +20 whp with E85 I guess my meth setup works really well then )
Here is some pics:
Zdayz 2016
Zdayz 2016
And some vids
1:20 on this one
Here is some pics:
Zdayz 2016
Zdayz 2016
And some vids
1:20 on this one
#58
Hey man good to see you again. I just noticed you have the DC headers. Are those the ceramic coated ones? If so, I would suggest to remove the heat wrap. I had mine heat wrapped and the drivers side cracked. Called and talked to DC, they said the reason for cracking is the wrap baked them and they said it voided the warranty. Just a heads up.
#59
