Need some turbo help
on
im looking into getting a turbo for my 2005 350z enthusiast edition. the one i am looking at is a "bolt on" GTM twin turbo (https://conceptzperformance.com/Cart...on.php?II=9355) it looks like it has everything that i need to install without having to really do anything but put it on. im wondering if anyone has used this or if anyone can give me some advise on the install process. im going to do it myself as well. im new to turbos but im not new to getting some grease on my hands. it has all of the injectors, fuel pump, oil and water lines, and intercooler\piping. i cant see anything that i would need that isnt included in this kit. if their is please let me know!
Is GTM still in business?
on
If your new to turbo kits, don't try to install a twin turbo kit in a z by yourself, and everyone is saying gtm is out of business so you probably won't be able to get it
on
im going to have a friend of mine who has a mk2 supra that he did himself help me. and im getting a set of megan suspension for the car as well. its not going to be the only thing that i do to the car. i just like to plan out what im doing. ill i looking for is some people to not be ****** and help someone out. i really dont see why thats so hard for people
on
I found a gtm kit for 5500 mean suspension for 1200 I have rims and all the gauges and wireing is less then 300. I am very capable of doing all the work myself. I have access to a lift a cherry picker and engine stand. Along with a full toolbox. I posted on the very first post the link to the turbo kit I am looking at. I just need someone to help let me know if it's good for daily and if theirs anything else I need to get other then gauges
if thats the kit you want and they have it (i'd call czp to be sure) then cool. Go with that, you will also need gauges, a new clutch, and prob a lsd. I would also recommend CJ motorsports stage 0 RFS, Tons of heat wrap/fire sleeve and def. a oil cooler setup with thermostat. Thats a start at least...start researching everything and buy it all. then pull the engine and slap it on. good luck
yes, gtm kits r bolt on, and u can run it on stock internals with nothing else. just bolt on, load the map they provide and be happy. just dont push over 10 psi, bc the stock might not hold, but i know its good for 400-450whp, thats a rough estimate.
although the cost of internals is another thing. i'm planning a tt set up and the bottom end tt kit exhaust and all the gauges only abt 20g
