2bad240's journey to the world of vortech
01-10-2016, 01:27 PM
Quote:
Originally Posted by
Resmarted
No bueno homes.
If you wrecked the motor, I'm considering going ls and would make a good deal. Jfs.
Got it apart and found I cracked a sleeve and blew a hg and eroded the top of the sleeve.
01-10-2016, 03:51 PM
So 11:1 and YSI isn't a good combo???
What fuel do you use?
01-10-2016, 04:04 PM
It's a Great Combo.......
01-11-2016, 03:36 AM
2bad240
Wow you should be proud. Hardly anyone has cracked a vq sleeve on here.
Think there was too much timing? Or that the hg let go first and then the sleeve took a sht?
It's possible that block just had a bad sleeve that didn't show it's self during machining or in the past
You have any thoughts on it?
Sucks to see that man.
01-13-2016, 02:35 PM
So I had another set of rods on standby. And I ordered a new set of Pistons and bearings. And this time went with hks head gaskets and arp L19 head studs. All the parts should be here Friday so hopefully il have it running this weekend.
01-13-2016, 02:57 PM
What are you doing about the cracked/melted sleeve? or do you have a spare block? Compression on next build?
01-13-2016, 03:02 PM
Conway_160
Using another block I have. Going 11:1 again
01-13-2016, 03:04 PM
2bad240
Good Luck good sir!
01-16-2016, 02:02 PM
So got a good bit done on my new engine today. Took there rods to machine shop yesterday to have them checked out came up with a few bent wrist pins and had to hone the small end on one rod. But I got new Pistons 11:1 stock bore like I had went back with hks head gaskets instead of HR and with L19 head studs over the standard arp's that I had. Don't mind the LS bashing in the pics my helper today drives a LS3 camaro
Rod in the hone
Bent wrist pin from old piston
L19s and hks gaskets
L19 vs standard
Hand filed the edges on main caps and block edges
Almost back together
01-17-2016, 11:57 AM
Almost ready to go back in
01-17-2016, 05:49 PM
What long tubes do you run?
01-17-2016, 06:09 PM
Resmarted
They are PPE
01-19-2016, 03:12 PM
Well it's back in and running
01-20-2016, 02:33 AM
Faster turn around than most big name shops.
01-20-2016, 05:55 AM
on
2bad240
[/URL]
What intercooler is that?
01-21-2016, 07:44 PM
01-23-2016, 06:58 PM
on
Resmarted
Treadstone
Thanks
01-27-2016, 02:03 AM
on
Thomas.
Thanks
Its the treadstone 1300hp version.
01-28-2016, 05:10 AM
on
Squishyface
spot on:
http://www.treadstoneperformance.com...cooler++1300HP
I wonder why are there no splitters in the end tanks?
01-28-2016, 01:47 PM
Thomas.
There are in the actual unit.
