Vortech jack shaft bearings on '03 g35 quest
apparently I've overtightened either the serpentine or the cog belt as my jackshaft bearings are "whirring" like crazy.
I've removed the housing/assembly and removed the shaft/bearings.
one spins fine (serpentine side) and the other is rough. Vortech made a huge deal on how the bearings are heated to put them on the shaft etc.
this will cost me over $350., and a 3 week wait, to get the whole assembly from them.
since this is a common problem... im also sourcing other suppliers for the bearings in the Toronto GTA area.
if anyone has gone through this exercise please post
manufacturer and part number.
my machine shop guru will find more than one way to install the bearings on the shaft.
btw removing the jackshaft assembly took a whole 10 min.
iideadeyeii (06-24-2016)
UPDATE
yes found them and they were $14 each....
what technique or steps did you use to remove the old ones from the shaft and put the new bearings back on the shaft ?
found this thread...
http://g35driver.com/forums/gallery/...ml#post7064801
but its old and see my reply at the bottom about the pressed ON bearings
I will do a full diy on this project
The following 2 users liked this post by OldManZ350:
BluestreamDE (01-12-2019),
harlie95 (09-18-2017)
ProStreetDriver
06-01-2016 06:38 PM
Surfer90291
05-29-2016 01:56 PM
