not boosting - 4000rpm @ -2 in*hg
dyno'd a week ago...my tuner pushed the car relatively hard up to about 4000rpm and I was only seeing -2.9 in*hg of vacuum where my 18g should be well into boost...
a boost leak somewhere but nothing is jumping out at me ... nothing obvious. If I'm expecting 12psi to 15ps around 4k rpm and I'm seeing -2 in*hg of vac the air has to be going somewhere.
No clear/obvious broken couplers/loose connections from the turbos to the TB.
the tuner suggested I check my waste gate valve seats - which I got the drivers side off last night (early this morning) and it's in place. Going to pull the passenger side next. Going to replace the diaphragms and hopefully install a waste gate relocation pipe (if I can find a kit).
Has anyone experienced something like this? known of a solution? or have any insight?
My tuner is Nick over at Mac
any help is appreciated -
hatersgonnahate
sounds like wastegate is open, bypassing the turbo
un install any EBC/MBC and just run WG first to check spool/boost. You should be able to hear the turbos spool up.
Tuan had his wastegates fail open (disc on end of rod broke rod end, stayed cocked)
^I appreciate the posts guys...it turns out I made a dumb mistake ... at first blush my impeller spins freely as I get closer to it I believe the blower has to be rebuilt it's got a good amount of play in it...fairly sure this is on me and if it's not, it's still on me...
two mistakes - first & foremost - I think I hooked the waste gates up wrong - used the top port rather than bottom side - I thought that's how they were supposed to be while not using a boost control solenoid and I didnt have the where-with-all to have someone with more experience review my setup.
second was not rebuilding my waste gates and having them sticky - the diaphragms look fine but I'll spend the $30 for new diaphragms, I'll replace my plunger valve seats($30) and do very good job cleaning the mechanics of the waste gate before it goes back on...
dumb dumb dumb...a $1500 to $2000 mistake...
I'll be digging into the passenger side here soon...
hatersgonnahate
you can get CHRA for 500.
top port is only when you run a boost controller. If thats how you plumbed it, then your turbos should have spooled well beyond 25psi or so. Leave the top port open.
yeah...lessons learned...I didnt over-boost like that...I'll be a little smarter once I get it buttoned back up...
theGentlemenZ
09-11-2016 12:32 PM
