RPS clutch problem plz help
Old 11-26-2016, 10:00 PM
350z-900whp
350z-900whp's Avatar
Exclamation RPS clutch problem plz help
Hi,
I have recently bought rps triple clutch am having problems with. The issue is hard engagement in each gear at 7200rpm when I shift the gear won't go to the next (3rd to 4th) or say (1st to 2 ), when the rpm drops then the gear would go in place! .
Am not sure if it's mechanical issue with pumps / fork or tuning clutch engagement point.
I have tried to retune engagement point and now the gear grind or become very hard to fit in place even under normal driving conditions
My transmission is 2003 original vq35de
Note
Previously I had excedy twin with no problem what so ever
Thanks
Old 11-27-2016, 02:02 PM
Conway_160
Conway_160's Avatar
Did you realign the shifter after you put it all back together?
Old 11-27-2016, 11:12 PM
350z-900whp
All fixed, I went to different garage and they fixed the engagement point every thing worked fine thanks all
