where to set rev limiter.
This are the specs of the motor. 04 z
Arias 9.5-1 pistons
Pauter I-beam Rod
Port and polished
3 angle valve job
balanced and blue printed
bored .020 over
wsx dry film lubricant on all bearing/friction surfaces
heat treated coating on pistons, valves and combustion chambers
Micro polished crank
HKS head gasket
Nissan HR valve springs
Arp head studs, main studs, and rod bolts
ACL rod bearing, main bearing, and thrust washer
Pathfinder cooling mod
PPE long tubes
N1 exhaust
Stillen oil pan
Revup oil pump
Fluidampr
1200cc injectors
e85 only
vortech with 928 impeller and bearings.
Factory cams
What would be a reasonable bump in RPM?
Arias 9.5-1 pistons
Pauter I-beam Rod
Port and polished
3 angle valve job
bored .020 over
HKS head gasket
PPE long tubes
N1 exhaust
Stillen oil pan
Revup oil pump
Fluidampr
1200cc injectors
e85 only
Factory cams
Oil pump for sure ... look into the nismo or look up Jeremiah/TotalD, sucker punch motors sports, he fabs up OEM pumps with upgraded internals...
Im bullt with factory heads like you and rev my DE motor to 7.2K rpm.
I have a flat poor curve from 6k-7.2k rpm but motor has been fine spinning to this on track for a good while.
