Stainless Steel Pod Filter - MY350Z.COM Forums
Thread Tools Search this Thread
Old 02-20-2017, 11:52 PM   #1
R6n350GT
Default Stainless Steel Pod Filter
Being low mount like Boosted Performance my filter gets a bit toasty.. Anyone used something like this
Totally unique, the entire filtration element is made from a fine stainless steel T-304 mesh (200 micron mesh and 150 micron crown). This mesh means the filter will never wear out, and have substantially less restriction than any other filter available today. Another feature is the super fine pattern of the mesh. This straightens the airflow and dramatically reduces aerodynamic turbulence."
And then use a K&N dry charger over the top. That way if it does get burnt (dry charger) then the filter should still stand up ok ?
R6n350GT is offline   Reply With Quote
Old 02-21-2017, 04:14 AM   #2
dcains
dcains's Avatar
"Another feature is the super fine pattern of the mesh. This straightens the airflow and dramatically reduces aerodynamic turbulence." Bullsh!t
dcains is offline   Reply With Quote
The Following User Says Thank You to dcains For This Useful Post:
pyshin (02-21-2017)
Old 02-22-2017, 01:38 PM   #3
R6n350GT
Quote:
That may be but will it be a bad idea for low mount due to filtration not being as good ?
Old 02-22-2017, 09:37 PM   #4
dcains
dcains's Avatar
A factory paper air filter/airbox will provide the best filtration, but that's rarely an option with a custom FI setup. Stainless better than cloth - I have no idea. Seems like the cloth might hold the filter oil better, so it might grab grit better for a while.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright 2002 - 2008, MY350Z.COM All Rights Reserved.
