Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > Tech Area > Engine & Drivetrain > Intake Exhaust
Old 07-19-2008, 11:20 PM   #1
Motordyne
Hydrazine's Avatar
Post Motordyne XYZ-Pipe (Pilot Production)
THE MOTORDYNE XYZ-PIPE.
Its a X-pipe. Its a Y-pipe. Its a resonated test pipe, cut out, diffuser, venturi, catalytic converter all in one.
This is the first of several new Motordyne exhaust modifications to come.
With configuration changeable modules being released, it is a fully optimized merge collector with many different functions and applications. Hence the name "XYZ-Pipe".
A lot of R&D went into this. It is where the majority of dyno, emissions and variability occurs in the Motordyne exhaust system.
Motordyne can't compete with the cheapest selling systems, but we certaintly can compete with and exceed the VERY BEST.
The pictures below are small sample of what is to come.
NOTE: This merge collector (XYZ-pipe) has been fully optimized on the dyno. Both the merge angle and merge distance relative to the engine were explored and optimized.
Exhaust gases can be merged just about anywhere, but in all of the testing performed on the Z, it was found that the further back from the engine the gases were merged, sound quality, throttle response and power degraded. If it was merged as far back as the rear axle, throttle response was significantly compromised.
If it was merged via a H-pipe between test pipes, low end TQ was sharply compromised.
After aquiring enough data points of different merge points relative to the engine, a plot was created showing HP Vs Merge Point. And in this curve there was a peak between the extremes. This is how the optimum merge point was found.
Seeing that the optimum merge point occured before the usual point where the stock Y pipe, or Nismo Y-pipe merge, I created a Y-pipe with a long straight section to fill the gap to the end of the stock Y-pipe location.
The prototype had nothing but a straight section of 3" tubing to go from the optimum merge point to the end of the Y-pipe envelope. This section of straight 3" tubing was screaming out "Use me for something!"
And that is when different modules, resonators, diffusers and venturies of varying diameters were experimented with. More to come.
The picture below shows a typical 2 layer flex line on the right and the Motordyne 3 layer flexline with an inner liner on the left.
Most exhaust systems use 2 layer flex lines to reduce costs but having the corrugated bellows exposed to the high velocity exhaust gasses induces, turbulence, pressure drop, buzzing and whistling. And definetly not recommend for FI applications.
The Motordyne flex lines are much less intrusive to the flow NA or FI.
The corrugations of the 2 layer flex line on the right don't show well in the picture but they go approximatly 1/2" deep.
Note the rainbow welds on the thick stainless steel flanges on the XYZ 2.5" primaries.
These flanges won't warp when welded or torqued. NO CORNERS CUT.
Overview of the XYZ-pipe in the "Y-pipe configuration with a resonator".
NOTE: the resonator really sweetens up the exhaust tone. I give it a:biggthumpup: for sound quality enhancement. It should be able to fit on just about any aftermarket single exhaust setup. AMUSE, JIC, FUBITSUBO, NISMO, ETC.
In the picture here, the XYZ-pipe with resonator, is also shown with a catalytic converter along side.
THIS IS SIGNIFICANT.
Many times people post the question. "Which should I get? Cats or Test pipes?"
With the XYZ-pipe, you no longer have to ask that question or make the either/or compromise. Now you can have your cake and eat it too.
When you install the usual test pipes or catalytic converters, you typically leave them in place because its such a pain to take them back out. Once they go in, that's it. They're done.
This is why the question "Cats or Test pipes" is so commonly asked on the forums.
Now, you can install the test pipes you've always wanted and still switch back and forth between cats and test pipes much, much more easily.
The catalytic converter is relocated behind the XYZ-pipe (underneath the car) where you can access and switch it out with nothing more than a set of jack stands on one side of the car.
The catalytic converter, straight pipe, venturi and resonator are attached to the XYZ Pipe via a "V-band" clamp with one nut on the clamp and two bolts at the aft flange section.
Now it is exponentially easier to switch between catalytic converter to resonated or straight pipe, ETC. Its so much easier that you no longer need a lift to do it. Anyone with jack stands can do it in less than 10 minutes.
THIS IS A HUGE, USER FRIENDLY, ADVANTAGE. Not to mention being very helpfull while at the track.
The exhaust shown below is one of my favorites.
Simple, effective, sounds awesome and purely functional. Loud, but not too loud.
A progressive, exotic sound that appropriatly increase loudness with RPM. Quiet enough for daily driving and it absolutely screams at WOT high RPM. When used with the Motordyne resonated XYZ pipe, it sounds like a damn Ferrari.
All 0.065" stainless 304 and weighs only 18 lbs.
The Z SHOCKWAVE!
Below are pictures of what will also be available soon.
The VQ muffler is very large and Very Quiet (VQ). No chambers. A straight through design with a single 3" inlet and dual 2.5" outlets.
Its probably too quiet for most people, but for some, its exactly what they want.
Below are previews of some Ti tips and the Harakiri muffler.
For the Harakiri Ti muffler, there will be a completely different kit than Shockwave. The Harakiri kit will be listed at ~$900 configured with the muffler in the back and a midpipe with no resonator. (Similar to the JIC.)
The Shockwave has a large resonator with no muffler and, as a kit, will be listed ~$600.
The parts are interchangable with eachother so there are a number of different sounds possible. From nicely muffled to very loud.
Especially when you consider the XYZ modular options and other mufflers comming out there will be many, many different sounds possible.
Below are the pictures where the camera doesn't do justice. On the Harakiri muffler, the colors shift slightly with view angle.
Harakiri and everything else Titanium will be available for the 350Z, G35 and G37.
There is much, much more to post but it will be posted after a little more progress is made.
__________________
Winner of Sport Z Magazine Plenum Mod Shoot Out --- A Fully Independant and Comprehensive Test Comparison
http://motordyneengineering.com/dynos.htm
Same car, Same day, Same dyno, Same gas, Same ECU resets before each set.
Hydrazine is offline   Reply With Quote
Old 07-19-2008, 11:27 PM   #2
Just Do It!
Chef-J's Avatar
Awsome xyz-pipe....
Need more info.
Chef-J is offline   Reply With Quote
Old 07-19-2008, 11:56 PM   #3
jammin's Avatar
Quote:
Originally Posted by Hydrazine
The Z SHOCKWAVE!
Is the bottom piece the tips?
jammin is offline   Reply With Quote
Old 07-20-2008, 12:00 AM   #4
Motordyne
Hydrazine's Avatar
Yes.
For at least one variation anyways.
EDIT - Note that what you refer to as a tip, is actually not a tip at all. Its a diffuser.
At WOT redline, the diffuser reduces exhaust pressure drop by 0.7 psi.
Its not much, but its one more engineering detail added to design.
__________________
Old 07-20-2008, 12:09 AM   #5
Newbie
Darkness75's Avatar
i`m so impressed, very nice and waiting to see it on a Z !! and dayno`s !! and clips !!!
p.s : any thing coming for True Dual Exhausts ? APS to be exact
__________________
350Z `05 Non-Rev ,stock exhaust ,Berk HFC ,K&N highflow airfilter ,MD 5/16" iso thermal plenum spacer
Darkness75 is offline   Reply With Quote
Old 07-20-2008, 12:09 AM   #6
thunshine booty
turismo's Avatar
Bootyfull
__________________
Greddy TT, Built Autobahn Longlbock, Vpro, 20in Gold GT30's, Stance GR Pro Coilovers, Stoptech 355f/r etc.......
turismo is offline   Reply With Quote
Old 07-20-2008, 12:18 AM   #7
_ink's Avatar
Interested in price and results gained.
Also confused with how the cat will attach to the resonator and still fit on an aftermarket exhaust system??
_ink is offline   Reply With Quote
Old 07-20-2008, 12:20 AM   #8
terrasmak's Avatar
My tanabe may be for sale soon.
__________________
Sure therapy, but screaming obscenities is cheaper.
terrasmak is offline   Reply With Quote
Old 07-20-2008, 12:30 AM   #9
Motordyne
Hydrazine's Avatar
Price
Its being worked on. The baseline XYZ pipe will probably be listed the same as the JIC Y pipe (while still offering a lot more capability).
Dyno plots
They are only valid when done independantly. You can be sure it will happen soon.
As for cats and resonators...
The picture shows only 2 of many different modules comming out. One of which will be a combination catalytic converter and resonator in one. It will clamp onto the XYZ pipe, giving you what is essentially a Y pipe with a built in resonator and catalytic converter.
It fits exactly the same as a regular Y-pipe. So if for example you had a Nismo exhaust with test pipes.
You can take out the Nismo Y pipe and replace it with the XYZ pipe with any add on module of your choice.
Straight pipe, resonator, catalytic converter, combination resonator/catalytic convertor, etc.
It will fit right in place of the Nismo Y pipe.
So if the Nismo had rasp, it won't after the resonator is added.
If the exhaust smelled bad due to a lack of cats, it won't if the XYZ convertor is used.
And its easy to change them out.
__________________
Old 07-20-2008, 12:39 AM   #10
FAIRLADYZ_MANnE's Avatar
if its not cheap n price then it will fail w/o hp gains proven
__________________
MODs: Mrev, 5/16 motordayne spacer/gutted cats/JWT PoP charger 06 FAIRLADY Z
13.7@103 60ft 2.03
86 Foxbody (T-Tops) Full exhaust/Smog delete/fully stripped
FAIRLADYZ_MANnE is offline   Reply With Quote
Old 07-20-2008, 12:47 AM   #11
Motordyne
Hydrazine's Avatar
Quote:
Absolutely true.
And that is why there will be independant testing. Unbiased, accurate and independant is the only way to go.
__________________
Old 07-20-2008, 01:06 AM   #12
jammin's Avatar
How many variations of the "tips" or diffuser? will there be?
Old 07-20-2008, 03:22 AM   #13
is the dfference noticeable
__________________
13.7@103 60ft 2.03
Old 07-20-2008, 04:41 AM   #14
mw9
mw9's Avatar
the quality looks amazing
__________________
KJR pulley, motordyne 5/16 spacer, rogue short shifter, all amsoil fluids, JWT popcharger, 350evo sways, AAM ypipe, helix tps, UTEC, Tokico HP blue, Tein S
mw9 is offline   Reply With Quote
Old 07-20-2008, 05:24 AM   #15
Lawn Dart's Avatar
Nice product. It's obvious that Motordyne isn't a company that just cranks out parts.
__________________
http://thecarspace.com/Teatang
Lawn Dart is offline   Reply With Quote
Old 07-20-2008, 05:37 AM   #16
You know that XYZ-pipe will confuse new members all to hell. They are still trying to figure out rasp.
__________________
350Z 2004 Enthusiast: K&N Typhoon Air Intake - Motordyne Plenum Spacer - Alphawerks Stainless Steel Headers - Helix SS Test Pipes - Injen Super SES Cat-Back Exhaust System - 6 Pad Puck Ceramic Clutch and Forged Steel Flywheel by Competition Clutch - WedsSport SA-70
davidv is offline   Reply With Quote
Old 07-20-2008, 05:54 AM   #17
Motordyne
Hydrazine's Avatar
Quote:
Three in total.
1) The Diffuser
2) Stainless Steel resonated tip
3) Burnt Titanium
__________________
Old 07-20-2008, 05:57 AM   #18
Motordyne
Hydrazine's Avatar
Relative to what? Sound, power, TQ
Butt dyno, ear, dyno?
__________________
Old 07-20-2008, 06:23 AM   #19
350Zenophile's Avatar
Thanks for bringing another well thought out product to market! Can't wait to see all the info to come.
350Zenophile is offline   Reply With Quote
Old 07-20-2008, 06:24 AM   #20
Motordyne
Hydrazine's Avatar
Quote:
Absolutely 100% true.
If I made it simple enough that it didn't confuse anyone, it would be the same, one size fits all, cookie cutter, system like every thing else on the market.
Its new, its different, questions will be asked and I will always be here to answer any questions. Same job I've always had.
Just look at my PM inbox... And this was yesterdays inbox.
J/K. That aparently was yesterdays forum download error.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
