for those with skunk2 plenum spacer
on
think the only ones your could really use would be the crawford, aps or the stillen, as these strut bars dont go over the plenum they are in front of it. It also depends on how tall the plenum is also. If it is a small skunk plenum then you can get some strut bar spaces and it should be fine
crawford
stillen
aps
hope that helps
crawford
stillen
aps
hope that helps
on
crawford
stillen
aps
hope that helps
crawford
stillen
aps
hope that helps
Be carefull installing that spacer, i would add some washers and be real careful with the torque on those bolts cause the way the head on the bolt is dug into the aluminum on my plenum and casued it to crack
allmycarsdie
05-13-2016 04:38 PM
04-04-2016 07:52 AM
