Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Engine & Drivetrain > Intake Exhaust
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 07-30-2010, 06:41 PM   #1
Z-33
Default 350z berk test pipes-ecu install
i came across this on berks website for the ecu reset after install.
1. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
2. Repeat the following two procedures quickly five times within 5 seconds:
1. Fully depress the accelerator pedal (HARD).
2. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 seconds.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to OFF position and now you can start the car. The CEL light should be gone.
has anyone done this? and has it worked?
im going to get them installed tomm, and wondering if the light does come on by chance, do these steps usually solve the problem?
thanks
Z-33 is offline   Reply With Quote
Old 07-30-2010, 07:19 PM   #2
Points: 9,433, Level: 65
Points: 9,433, Level: 65 Points: 9,433, Level: 65 Points: 9,433, Level: 65
Today's Activity: 99.9%
Today's Activity: 99.9% Today's Activity: 99.9% Today's Activity: 99.9%
I installed test pipes. No problem with ECU.
Note: Disconnect battery before installing.
__________________
370Z 2009 Sport Package
davidv is online now   Reply With Quote
Old 07-30-2010, 07:20 PM   #3
Hammer031
Points: 552, Level: 11
Points: 552, Level: 11 Points: 552, Level: 11 Points: 552, Level: 11
Today's Activity: 1.4%
Today's Activity: 1.4% Today's Activity: 1.4% Today's Activity: 1.4%
the cel light will come one once you drive on the high way for a bit.
I'v seen this before and heard it works, I'm going to try it myself when i get the chance. Ill check back and see if it worked for you. GL
Hammer031 is offline   Reply With Quote
Old 07-30-2010, 07:21 PM   #4
stevehl
stevehl's Avatar
Points: 3,720, Level: 38
Points: 3,720, Level: 38 Points: 3,720, Level: 38 Points: 3,720, Level: 38
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
That would be the long, recommended process of resetting the ecu. The easier, faster way is to disconnect the battery, I can't remember off the top of my head if it was just the negative, or positive side, I forget which one I did, and then just press the gas pedal a few times and leave it for a few hours. Should be reset.
stevehl is offline   Reply With Quote
Old 07-30-2010, 08:50 PM   #5
Z-33
alrighty thanks for the quick responses. ill let u know the outcome, if the light comes on.
Old 08-07-2010, 02:36 PM   #6
Z-33
hey guys just do do a follow up. i followed the steps listed on berks site for the ecu reset but it did not work. i tried multiple times, bc i heard you have to be spot on with ur timing, i even used a stop watch but it still didnt work. i have an 06 an i heard it doesnt work with this yr. however i did follow stevehl steps by disconnecting the battery (its the negative not the postive) and it worked !!! thanks for the tip.
but stevehl is this just a temporary fix or do you have to do it occassionaly disconnect the battery bc the check engine light returns?
Old 08-07-2010, 02:52 PM   #7
cdoxp800
Master
cdoxp800's Avatar
Points: 3,823, Level: 39
Points: 3,823, Level: 39 Points: 3,823, Level: 39 Points: 3,823, Level: 39
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
5. Wait about 10 second.
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
I have used this and it worked fine
__________________
2006 (RevUp) Silver Alloy Metallic, GTM Stage4 HKS Gt Supercharged 350z. (Sold)
2011 Brilliant Silver NISMO 370z. #: 0046
cdoxp800 is offline   Reply With Quote
Old 08-07-2010, 09:40 PM   #8
singh
_______________
singh's Avatar
Points: 4,240, Level: 41
Points: 4,240, Level: 41 Points: 4,240, Level: 41 Points: 4,240, Level: 41
Today's Activity: 4.6%
Today's Activity: 4.6% Today's Activity: 4.6% Today's Activity: 4.6%
Send a message via AIM to singh
i use this all the time immediately before I go get my inspection sticker. It takes away the CEL for about 40 miles
__________________
07 Magnetic Black Enthusiast 6-Speed | 20% Tint | Berk Test Pipes | AAM Competition Y-Pipe | Nismo Exhaust | Bridgestone RE-01R
singh is offline   Reply With Quote
Old 08-08-2010, 01:07 PM   #9
Luong
Points: 1,427, Level: 21
Points: 1,427, Level: 21 Points: 1,427, Level: 21 Points: 1,427, Level: 21
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
I stuffed the anti fouler that berk provides with their 08 test pipes with really fine steel wool and re-connected the o2 sensors. Did the ECU reset procedure and passed emissions. Before that I would just delete the code with a scanner but it would come up around 15-20~ miles.
__________________
2008 PPWPersonal, Works Bell, Fujita, Nismo, Falken, Eibach, ARC, HKS, Berk
Luong is offline   Reply With Quote
Old 09-27-2010, 04:28 PM   #10
ZPHILE
ZPHILE's Avatar
Points: 2,442, Level: 29
Points: 2,442, Level: 29 Points: 2,442, Level: 29 Points: 2,442, Level: 29
Today's Activity: 1.7%
Today's Activity: 1.7% Today's Activity: 1.7% Today's Activity: 1.7%
Anyone know why HFC/testpipes with the bung for the sensor trips the CEL in the first place?
__________________
2008 Carbon Silver ZR
ZPHILE is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
07, 350z, 370z, battery, berk, cel, disconnect, disconnecting, ecu, hard, install, pipes, reset, test, tp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
