TP rattling
TP rattling
I have been researching for about 2 hours now and I can't seem to find a fix for the rattling on decel/ low rpm from the test pipes. Every video I have watched on YouTube seems to have that same damn rattle as well. Some people say the pipes are rubbing against the heat shields, others say it's normal VQ firing order that causes it, and some say it's because the flex pipe is broken. I'm trying to keep my stock catback for now and just replace the cats with TP's but if it's going to rattle I don't see the point. Yes I know there are gains to be made by this mod but I don't think I could live with the rattle. Someone please let me know what's up.
Master
wrong, it actually gets hotter. the stock cats already have their own heat shield, when you get rid of those that area gets hotter. when stopped i can feel the heat come up the side of the door. coming right off the header it is going to be hot as hell no matter what you have
Master
they have stick on stuff, but you would have to clean the crap out of that area to make sure it sticks
http://www.autozone.com/sandpaper-an...hield-material
Master
but i am not sure how well that will work honestly... if you were to see your heat shield there now, it is raised off the body some so there is a gap, so the metal deflects the heat and the space between it and the underbody helps keep the underneath cooler, make sense? i mean you can always try it and worst case you put the shields back on
So I have the berk TP's installed and they do not touch any heat shields at all, not even close. They rattle like crazy at 2500rpms and on decel. I don't understand what's going on. All the bolts are tight, the are bolted to the trans mount like the stock cats.
