CAI vs 06 stock intake
Okay I need help. I have some cash and want to do some mods to my Z. I have searched high and low and haven't been able to find an answer. I have read in multiple threads that the 06+ stock intake with a drop in K&N is the way to go. Admin tuning posted a thread on FB the other day saying their set up makes more HP than any intake out there. I asked what this was compared to and he said 03 and 04. He didn't have dyno tests for the 06 with stock vs Admin but said their system was better. Does anyone have a link or the results of a true CAI (Admin, Injen, AEM....) vs stock 06 possibly with a drop in K&N? Please help I don't want to spend the cash for just sound. I am cool with spending cash aso long as I get some gains. FYI 06 6 speed. Future plans Motordyne lower intake and 5/16 spacer and up rev tune.
Hey
Admin tuning/furookie is a bigger intake pipe diameter 3.5 inch
There is also LMR which is 4 inch
all these REQUIRE a tune (~$500) due to the larger size and will definitely make more power.
other CAI stay within stock size parameters and the gains are negligible either the same or worse as 06 air box with k&n
the enclosed design of the stock air box is very well designed, and i believe stillen's intake follows a similar design and is the only one i would get if i was not going bigger.
another note is that the stillen air box will hold the admintuning intake (i emailed them myself to ask)
good luck with your choice but don't think too much about intakes unless you're going bigger lol
General & DIY Moderator
Welcome- and while you've searched "high and low" there's a myriad of threads on CAIs and the conclusion is the same. Nissan did a good job with the design of the OEM intake and there aren't any appreciable gains to be made by a simple bolt-on unit without a tune. There have even been some losses documented with some aftermarket units, so save your money.
Thanks guys. So if I do the Admin (larger) a tune is required to feel the gains. I wasn't sure as I haven't found anything comparing the Admin and the 06. So I will hold off on getting it until I'm ready for a tune. Thanks again!!
General & Tech Moderator
Bang/$ I would go with the HiFlows, although some might enjoy the induction sound.
.02
