Plenum help
Old Jun 21, 2004 | 09:29 PM
sponsorsthisway's Avatar
sponsorsthisway
Default Plenum help
So i've been doing some research on the plenums and i would appreciate it if some of you guys could help me clear some things up. From what i gather, the kinetix is cheaper than the crawford and you get to keep your stock one. However, the kinetix, is having problems with cracking? BOth produce relatively the same amount of power but with the Crawford you need to send them your old one after they send you their modifided plenum and you have to buy their strut bar. This one has not had any issues with cracking? Also, with any of the plenums is it possible to still use the plastic cover? Thanks in advance!
Old Jun 22, 2004 | 03:19 AM
zachcrosen's Avatar
zachcrosen
Default Re: Plenum help
With the Kinetix plenum you retain the plastic cover and the strut bar. With the Crawford plenum, you must buy the Crawford strut bar and you DONT get to keep the OEM plenum. From what i have heard, you also cant use the plastic cover unless you do heavy modding to the cover. Kinetix has a V4 plenum that they just released and it is supposed to be around 40% stronger. My vote goes for the Kinetix plenum, but thats just my $.02
allmycarsdie
May 13, 2016 04:38 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
