Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Maintenance & Repair
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 04-20-2005, 06:01 PM   #1
painkillerzz
Default My Oil Pressure is at 5psi
I have been battling this issue for a couple days now.
http://www.my350z.com/forum/showthread.php?t=117216.
I took the car back yesterday, because I wanted them to take a look at it again for the low oil pressure at warm idle. My oil gauge read oil pressure at 5psi, and their equipment measured oil pressure at 7psi at warm idle. I thought, because of the post that I have read, that anything less than 15 psi would be bad. However, when the dealer called the Nissan tech line, they were told that 7psi is still "within specs". Nissan tech line stated that as long as the oil light is not coming on, there isn't a problem.
Has anyone gotten this response from Nissan on this low oil pressure issue. If so, is there anything I can referrence, if/when I speak to them? For those that stated that oil pressure less than 15psi would be bad, was this information received from Nissan, or where did you get that information. I am just looking for documentation that I can present to Nissan, if indeed 5 psi is not healthy for the Z's engine.
thanks
painkillerzz is offline   Reply With Quote
Old 04-22-2005, 07:46 AM   #2
MA4
Points: 3,524, Level: 37
Points: 3,524, Level: 37 Points: 3,524, Level: 37 Points: 3,524, Level: 37
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
oil pressure is related to RPM's when you first start your car up the engine runs at higher rpm's to warm up the engine. once at normal operating temperature, the car will decrease the idle rpm's and your oil pressure will go down. When you step on the gas your rpms and oil pressure will increase. My 350Z's oil presure reading is exactly what you are describing and sounds normal. I did notice that my oil pressure will go below the 5psi mark around the time I am due for an oil change...probably because the oil is thickening up and becomes slightly harder to pump at low rpm's
MA4 is offline   Reply With Quote
Old 04-22-2005, 09:14 AM   #3
painkillerzz
ok at least I am not the only one. It just happened all of a sudden, and wanted to be sure it was "normal"
Thanks
Old 04-22-2005, 02:48 PM   #4
bwilliams
Normally, your oil pressure is a little higher when starting a cold engine for two reasons: 1) higher rpm, and 2) colder/thicker oil.
As car warms up, choke comes off and oil heats up and thins a little.
Older oil will be thinner due to chemical breakdown (yes, that's not a good thing) and therefore will result in lower oil pressure. It's a cue to change your oil.
I've never seen my oil pressure drop below 20psig, even after running hard in the summer. 5psig would concern me. If I had your condition, I'd make sure Nissan knew about it, in writing. I would also look at changing oil viscosity.
bwilliams is offline   Reply With Quote
Old 05-11-2005, 05:59 AM   #5
bknezevic
What's the recommened viscosity for a 350Z with around 4500 miles on it that lives in Georgia (90+ degree weather in the summer with humidity that makes it feel like its 110).
bknezevic is offline   Reply With Quote
Old 05-18-2005, 04:02 PM   #6
bwilliams
choice of engine oil viscosity, my viewpoint is:
For a fresh engine, i suggest sticking close to the sevice manual recomendations,
5W-30
Save the thicker stuff for over 50k miles (or over 80k if you treat the engine very well) when the bearings and bushings get a little more clearance.
Old 05-18-2005, 06:38 PM   #7
bknezevic
5W-30
So Castrol Mobil-1 Synthetic 5w30 is good then?? What brand should I get?
Old 05-23-2005, 04:28 PM   #8
bwilliams
The brand of oil is not that critical as long as it's one of the main stream name brands. The time between changes will have a bigger difference in longevity of your engine.
Old 05-25-2005, 01:31 PM   #9
GWAPITO69
Points: 3,280, Level: 35
Points: 3,280, Level: 35 Points: 3,280, Level: 35 Points: 3,280, Level: 35
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
I don't pay attention to the oil pressure but today it seems kinda high when i rev to 3500rpm my rpm is above 60 is this normal for our car? sorry for the newbie question.
GWAPITO69 is offline   Reply With Quote
Old 05-25-2005, 04:20 PM   #10
bwilliams
Your oil pressure sounds fine.
Mine does 25psi at idle, 75psi at 3000rpm cruzn. I never look at other rpms.
Old 05-28-2005, 01:04 AM   #11
spn350z
FROM ERVICE MANUAL:
idle
spn350z is offline   Reply With Quote
Old 05-28-2005, 01:15 AM   #12
spn350z
Default From service manual oil pressure spec
Oops.......
From ESM more than:
idle 98 kPa, 1.0 kg/cm2(square) or 14 psi
2000 rpm 294 kPa, 3.0 kg/cm2 or 43 psi
6000 392 kPa. 4.0 kg/cm2 or 57 psi
Old 05-28-2005, 10:28 AM   #13
bknezevic
do you have 10w30 or 5w30...what was your break-in procedure like??
I just put in 5w30 Mobil Synthetic and its exactly as it was with regular oil...
Old 05-30-2005, 04:16 AM   #14
bwilliams
I use 10W30 oil.
My break-in was mostly by the book (mileage and rpm).
Never over the rpm limit.
Very easy accel with an occassional brisk accel.
I kept this up for additional 2k miles (about a month) because I did a lot of highway driving. While on the highway, I changed speed a lot and would stop and rest every 20 miles.
My current oil consumption is less than half qt every 4k miles.
Old 05-30-2005, 07:26 AM   #15
bknezevic
I use 10W30 oil.
The 10w30 explains your higher oil pressure then.
Old 05-30-2005, 09:20 AM   #16
bwilliams
Yes, it may explain a portion of the different oil pressure. I suspect most the difference is just difference in oil pump, sensor, transmitter, etc... many variables.
My350Z
350 Z
Paid Advertisement
Tags
350, 350z, 5w30, bad, engine, healthy, heats, highway, hwy, low, nissan, oil, pressure, pump, spot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
had a terrible scare with my car last night!! phunk Forced Induction 19 10-12-2007 09:53 AM
My Z is in a little pain **lots of pics** MADScientist Forced Induction 88 10-11-2007 03:07 PM
Review of JWT TT at Firebird East track knight_white99 Autocross/Road 29 05-17-2006 12:48 AM
oil pressure really low...... tripmachine 2003-2009 Nissan 350Z 16 01-11-2006 12:44 PM
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
