Replaced steering wheel and now have airbag, VDC, and SLIP lights
on
I replaced my steering wheel with another factory steering wheel because my leather was wearing out on mine. So anyways i disconnected the battery and put on the new steering wheel with my old airbag. And now the airbag light will flash AND the VDC and SLIP lights are on and will not go off. I have absolutley no clue why it's doing this. So any help would be appreciated.
The air bag light might just have to be reset. There is a reset procedure for it in the service manual pm me if you need it sent to you. Hopefully you were gentle with the clockspring when you took the wheel off.
on
Well i got the airbag light to turn off by doing the key trick. But still as soon as i start to drive the slip will come on and automatically activate the brakes and then both the traction control and slip lights will come on and it will drive fine...
on
The fix is easy, but tedious!!. It happened to me before as well...I hope you will understand the following:
You left the steering sensor (located in the black spiral cable disc directly underneath the steering wheel which you can turn) in the wrong location when you reinstalled the steering wheel. I have attached a picture of the black spiral cable disc outlined by the red circle. The steering wheel sensor is sending back that your wheels are turned when they are actually straight, thus setting off VDC. You just need to turn the spiral cable disc back to its true center position. What you need to figure out is how many 360 degree turn(s) your sensor is off by in the wrong direction. First try to figure out which direction you turn the steering wheel sets off the VDC. Then remove the steering wheel, turn the spiral cable disc by a full 360 degree in the opposite direction (at least that's what I remember). Reinstall the steering wheel and retest. Hopefully you are only off by 1 full turn. Volia!! you fixed your problem. Let me know if you need any further help.
on
OMG you are awesome!!!!!!!!!!!!!!!!!!!!!!!! I didn't think spinning it around would mess anything up. But all i had to do is do one full 360 to the right and now it's perfect! And to think i was actually going to have to take it to Nissan since i was stumped on this one. Thanks again!!!
Got Track!!!!!
on
I thought this would be great to bring back, since a few people are installing aftermarket wheels, and some are having this problem. Myself included. I am going to go to the garage and see if this will work for me. If this does When need to Put this in the DIY
Try and wake this thread back up. I myself have a air bag. Slip. Vdc light that is on. I did all of the above. Lol. Removed my steering shaft to get motor out, steering wheel was somewhat disassembled to get to trim pieces. Like I said I have all them lights on as well as my left turn signal will not cancel out after turn. I have no clue where to even start. Anyone have and ideas?
This is what you need to do, end of story...
on
I’m so close
I have been trying to do what your saying and im so close if u turn it a little to the left when the wheel is back on the vdc comes on but when I take it off and turn the steering sensor to try to get it to the perfect position it just won’t it keeps turning on the light no matter how many times idk if it’s just off by 1 degree or something or if I’m supposed to try to get it to center when it says vdc off please help me
Help I still have vdc and slip light
