LH Headlight Low Beam not working!
Great to hear everything worked out. Three locations is odd, but I am sure they have reason as in your case! If it wasnt for those locations your ECU would be fried. .......
I would still love to see some pictures of your HID harness plugs & bulbs so I can possible add a home made HID kit of my own.
on
Originally Posted by ecorona6
FYI...the IPDM is behind the battery and it helps to remove it along with the plastic covers around the area, so you can remove the plastic cover from the IPDM box. Once in, you have six headlight fuses, 1 LH High, 1 RH High, 1 LH Low, 1 RH Low and also 1 seperate LH & 1 RH fuse. I am certain the low is blown. The first fuse to blow is in the IPDM box. Let me know.
If so man I am sorry, but I deleted your PM by mistake that told me which fuses are the low beams for the headlights... Can I get them again?
Thanks for any help.
Jonathan
Originally Posted by Peking
Hey folk this might sound weird... But did I PM you a couple of weeks ago about what fuses are the Low Beams because I need to change them out with the fuses that came with my HID kit?
Jonathan
Jonathan
350Z_Al
10-29-2020 07:44 PM
