Tire FEATHERING: FYI
#61
Originally posted by A17Z
i believe the feathering effects Zs built on and before september 18.
#62
on
when is the feathering usually occuring for people?? I've got 2,500miles on my Z so far. If this becomes a problem.. i might just get new tires along with some new rims
#66
More Tires
Has anyone had any good experience with the Bridgestones? I'm seeing lots of complaints, but I'm wondering if anyone is happy... especially in warmer clients.
Opinions from anyone in warmer climates (i.e. Souther Florida, SoCal) would be much appreciated.
#67
on
Re: More Tires
Well, I must admit, I am not totally turned off of the oem Bridgestone 040 tire. I have 14,450 hard miles on my Z and I would guess that the rear set will go for a total of 22 - 30k miles, even with my hard usage. Now, the fronts are already shot insofar as a quiet ride is concerned tho I would guess there is 50%+ treadlife left in the center section. The inside inch or so has been badly feathered due to misalignment from day of purchase and not the fault of the tire mfg. IMHO. The only area of complaint I have with the oem tires is that they are so quiet up to the point of loss of traction and beyond. I never really know (by sound) when I have lost traction or how much traction I have lost, only by the revs.
The dealer is replacing the front tires this week and it has been aligned so I hope the problem is being taken care of.
Oh, I am in Arizona so no cold wx. tire problems here. Regards, Jim
#68
What psi do you have in the tires? Nissan recs 35 cold in all 4. You may be experiencing alignment AND underinflation. If its worse on the inside than the outside, alignment is a suspect, if its worn less on the outside, it may be underinflated too. You should take it to your dealer ASAP before it gets worse. I would check the psi now, I don't think it should be under 32psi cold, IMO. You could talk to a Bridgestone dealer too.
#69
I dropped my car off at the dealer today, and the service manager just called me. Evidentally, a Nissan rep was there today, and mentioned that new TSBs will be issued tomorrow (3/6/03), one of which will be on the feathering tire issue. I'll keep you updated when I find out more answers.
#70
on
I have been working with my dealer on the same tire feathering issue. My front tires are in really bad shape. To date they did an alignment and my toe-in was off. I have copies of the alignment numbers before and after they check/adjusted this. I can try and scan them in if anyone is interested, no idea really how to read them though.
Per the Nissan TSB, they cross swaped the front tires, but even so the feathering is so bad the road noise is aweful. I'm going to let it ride to see if the feathering comes back before I push for new tires.
So far so good...
So far so good...
#71
on
aggie, How many miles on when they reversed the fronts? I had about 11,000 when they finally did mine and the noise went away immediately and I was a happy camper That is, for the next few hundred miles, then it came back w/a vengeance! Noise from 85mph down rather than 25mph and down. Interesting that your noise never went away.
I would like to see that alignment spec that they gave you. I couldn't get mine. Will you post? Thx, Regards, Jim
So far so good...
So far so good...
#72
Re: Re: More Tires
#73
on
Re: Re: Re: More Tires
Whoa! That is ugly tire mileage. I run at the strip every Saturday and occasionally Wed. nite as well as lots of other nefarious wheel spinning activity and I appear to be getting 3 times the wear. I dunno, maybe the road/track surface is more forgiving out here in Arizona! Regards, Jim
Originally posted by droidekaus
You must not be driving that hard. I had 1/32" left before hitting the wear bars on my rear 040s at only 7100 miles.
#74
#75
Re: Re: Re: Re: More Tires
#76
Originally posted by Boomer
Did you hit the wear bars across the tread or only on the inside shoulder?
#77
These were the rears. All of the way across. Besides the feathering, the fronts still had a good 3/16" left on them.
#78
on
Let me try and get the specs scanned in today, and I will post.
I had about 6000 miles when it first started, the tires were cross swapped at 8600 miles. My feathering was so bad it doesn't matter if you turn the tires sideways, I'm getting the road noise because the tires are ruined. I discussed with the dealer the idea of tire replacement and we both agreed that we wait and see if the feathering comes back again before taking that step. Not that they confirmed they would replace them, but I'm not done with them on that either.
#79
on
Courtessy Nissan
Anyone dealt with Courtessy Nissan and the tire feathering? Since this is the closest dealership, I'd rather take it to them if they have handled this issue before.
Is the TSB actually out yet?
