rattle in trunk is threatening my sanity
on
Glad you found where the rattle came from. I'd have to agree that trunk rattle is one of the most annoying things in the world. I'm not sure where you are exactly referring to on "two panels where the trunk closes," but I'd buy some sponge foams, cut it to desired shape, and double side it to one side of the panel.
I guess squares of foam of dynamat should do the job. I'll check out those solutions!
I've not experienced,the trunk rattle.But an annoyance of the Z is noise comming from the trunk and wheel wells.There is very pood insolation overall.Furthermore,due the design,the rear wheel wells are IN the cabin,not in a seperated trunk.I took a "whatever
it takes" approach.Lined the trunk with a combo of Dynamat and roof insolation(This stuff is cheap,works great,has adhesive backing).Also,remember reading a weird post about a guy that stuffed old shirts,towels...anything ya got in your closet you are gonna throw out,in&around the spare tire.His "theory" was that the wheel of the spare acted like a "drum"...resonated sound...strange?Well,gotta say,it worked!
I've been in other Z's.Mine,with my exhaust mods,is the quietist inside.Maybe not
at a g35 level,but pretty mellow.
Who da thought?
Who da thought?
Who da thought?
Who da thought?
My trunk rattle is coming from the underside of the trunk lid. the closet plastic peice to the left, just left of the rear window, pops out and makes high pitched chirpy bird sounds. I'll take it apart later and see what i can find.
Doesn't really matter if the thread is old if the information in my post is still useful. Why did you even bother replying with nothing of use? Anyways, this thread will never "die". As time goes on, troubleshooting these rattles will become more and more necessary.
Only solution: All panels off from the rear speaker garnish back. Stick Dynamat Extreme to exposed metal surfaces (at least 60% coverage and plastic mating surfaces). Take panels off the hatch. Add Dynamat Extreme (same deal). Add Dynamat Extreme trunk kit. Add heavy-duty hatch struts if you don't already have them. 75% chance the rattles will disappear (mine did). Lose some weight to make up for the added weight of the Dynamat Extreme (you'll gain it all back, but so what?)
on
The rattling I have come from the trunk lid springs. These springs create a gap when the lid is released for fingers to lift the trailing edge. These springs are not visible as a coil spring as they have a black rubber boot. They are about an inch or so in diameter.
I can duplicate the noise while the lid is latched by giving it a lateral push. At one point, I tried to make these springs compressed a bit more by adding shims made by several layers of duct tape, but the noise persisted.
I suppose I could take them apart and see but I keep forgetting that since the Z is my wife's daily driver/winter beater and she doesnt seem to mind the noise. I'll update this thread or create a new one if I found a solution other than removing them.
Master
#38
on
Ok I just bought a 2008 350Z with 46K on it, in excellent shape. When I test drove it, I was on a completely smooth road so no noise, but boy the next morning heading into work " it was like driving around with aluminum cans in the back of the car". So I did a google search for "rattle in the back of 350Z" and was lead to My350Z.com and another thread that talked about the upper shock bushings and replacing them. Today I put in the KYB SM5482 kit on both sides, simple, took about 2 hours total. Lubed everything with white lithium, made a upper "shock to body" gasket out of Felpro gasket material and the noise is COMPLETELY GONE. $30.00 , cant beat that!!
#39
Master
glad you searched and found this, rare occurrence for most new members. with you having the hr, when the slave goes out (and it more than likely will) replace with the Z speed hd one.
btw, when i was in CO last year , went to the Garden of the Gods in colorado spring.... freaking beautiful. texas is flat and boring
#40
on
HR? Slave?
HR? Slave?
