HELP!! Car wont start but everything else turns on
on
My car won't start up! Its not the battery because everything turns on (radio, lights, windshield wipers). What could it be?! Last night everything seemed to be fine when I went to get gas but when I woke up right now this happened :[ I installed my exhaust a couple weeks ago but it has been running fine. Could the new exhaust probably done something??!? Please help!
on
on
or it still could be the battery because my was running just fine no problems what so ever and then the next morning my battery killed it's self and nothing was left on....everything still turned on in my car wipers worked window but the battery would even turn the motor. bought a new one boom worked just fine again
on
on
Originally Posted by 2007-Z
So turn the key to the run position, check the voltage on the gauge... Also, does the engine even try to crank? The immobilizer system will cause the starter to not even move.
It should say 14 volts I believe
on
If a bad key is used the engine will still turn but the vehicle will not start. Sounds like a battery problem. The voltage gauge will not tell you anything about the battery. Do this....sit in the car and put the window down. start to move the window up and turn the key to try and start the car. If the window slows down significantly then you need a battery.
on
If you're sure you have battery voltage, and your car will NOT crank, you likely have a starter issue. I'm new enough to these cars that I don't have any knowledge about this immobilizer system people have been talking about. If you have a voltmeter handy, put the positive lead on the cable going to your starer from your battery, and the black lead on the frame or wherever you can get a decent ground. You then need someone to attempt to start the car. You should get battery voltage (around 12v depending on battery condition) while they are turning the key. If you do get voltage, likely your starter is the culprit. No or low voltage would point to your battery, but really could be a number of things from bad connections to a relay, or maybe even a bad clutch-engaged switch if ur MT.
If you're not mechanically inclined, get a buddy or just bite the bullet and call a shop.
I really doubt the exhaust work caused anything btw.
Oh and if you are MT, try push starting it.
on
Originally Posted by cheshirecat79
I didn't catch if the actual engine turns over- if not, could be the clutch pedal sensor not depressing. The car won't crank period if that sensor gives a problem.
do you know if this starting problem would be the same as a g35 coupe.
my car can't start too. battery is well charged it will crank up the motor but it wont start. also when i put the ignition on the "on" position my radiator fan goes on and my slip indicator light goes on as well, but the CEL light does not light up. anyone know what the problem could be?
Just because all your Secondary voltage requirements are working dosent mean the Battery has the ability to operate the Primaries. ALWAYS start from point "A" and dont assume ANYTHING.
Check the battery to see if it is 100%, Check and clean your Terminals, Follow the path of the Primary circuitry and verify full voltage to the destination.
