How-To Repair Stuck / Broken Window Motor ...
Old 11-14-2008, 11:04 AM
  #161
VO...
Administrator
VO...'s Avatar
Received 2,747 Likes on 1,836 Posts
Glad I could help...
Old 11-23-2008, 04:31 PM
  #162
ZKansasZ
ZKansasZ's Avatar
I finally got off my lazy *** to get the new windor motor installed.
So I want to say THANKS A BUNCH to Vo7848 because without his DIY, my job would have been so much longer and more painful.
So I give him the credit that he totally deserves to have!
THANK YOU once again, Vo7848!!!
Old 12-02-2008, 10:32 AM
  #163
RedBullRR
RedBullRR's Avatar
Have you had to clean it since? And is this covered under warranty. My window is now doing this and I swear I just got the car back from Nissan, I just dont want to deal with there crap anymore.
Old 12-05-2008, 12:24 PM
  #164
VO...
Administrator
VO...'s Avatar
Thank you for the kind words sir...
Yes, the initial cleaning lasted 2 months, then it failed again. I ended up replacing the motor with the refurbished one from Advanced Autoparts. It's been several months now and I've had no problems...
Old 12-07-2008, 02:53 PM
  #165
GSXRChino
GSXRChino's Avatar
very helpful...thanks...+1
Old 12-10-2008, 01:27 PM
  #166
JROCK 2003
JROCK 2003's Avatar
I assume this DIY will hold true for the driver side door as well? Minus the screws for the " oh Sh*t Handle" ?
Old 12-10-2008, 08:13 PM
  #167
J350z101
J350z101's Avatar
Thanks alot!
Old 12-17-2008, 01:54 PM
  #168
VO...
Administrator
VO...'s Avatar
Werd...
Old 12-17-2008, 02:01 PM
  #169
hubcityz
hubcityz's Avatar
i had problems with my driver sider window, the motors was shot i just replaced it yesterday. i tried to clean it first but that didnt work, thanks for the advise but i had to bite the bullet and buy one, it was 180.00
Old 12-18-2008, 03:25 AM
  #170
Alanos
Alanos's Avatar
Yesterday i had used in good condition motor and my old used motor.Cleaning won't help much because the two clipers(closing in) which holds the internal spining part are geting thin by using it.Then internal thing is not touching to second part and window is not working even if it is clean
Old 12-30-2008, 04:04 PM
  #171
Lonny
Lonny's Avatar
Great post, vo. Very easy to follow. Did my driver's side window today so I'll see how long it lasts. BTW, one of the brushes was stuck in the sleeve. I sprayed the contact cleaner in from the back side by sticking the straw in between the black plastic casing that holds the brushes and the white plastic inner liner. That got the brush unstuck. I owe you a beer or ten.
Update 3/2011: Still working after more than two years. No problems.
Old 01-02-2009, 01:42 PM
  #172
03aeroZ
03aeroZ's Avatar
Just an FYI: I went to order a window motor at Advanced Autoparts, the same motor everyone else has. If you have the free AutoZone rewards card, and if you let them cut it up, you get 20% off of your order. Thinking about having the wife or someone sign up for it and then get the motor for around $100 with the core exchange, save about $50.
Old 01-07-2009, 09:44 PM
  #173
TTwinTTurbo
TTwinTTurbo's Avatar
I just completed the install. Only hard part was getting the metal square thing (lol lack of name) to go in space for it. So I tooke the spindle out and moved it to where it mated up then attached it to the regulator. I then used a hair pin thing to hold the brush in and pushed the spindle all the way in. Works like a charm and only costs 144.95..autozone
Old 01-12-2009, 08:56 AM
  #174
VO...
Administrator
VO...'s Avatar
Originally Posted by Lonny
Great post, vo. I owe you a beer or ten.
Deal!
Old 02-02-2009, 08:22 PM
  #175
travislee
travislee's Avatar
damn Nissan window motors..i purchased a motor from a guy on here that said it has around 12000 miles on it, should i clean it before installing it?
Old 02-03-2009, 06:28 AM
  #176
VO...
Administrator
VO...'s Avatar
Since the motor has not been installed, I wouldn't see why not. A little cleaning wouldn't hurt...
Old 02-03-2009, 05:18 PM
  #177
350ZVB4ME
350ZVB4ME's Avatar
Default 06???
Awesome, awesome post!!! Stupid question, but the reset procedure here is the same for my '06, correct? I have the problem where I close the drivers door when the window is closed it goes down halfway. No problems otherwise with the operation. The dealer has told me three different things now, but always failed to mention the internal reset switch... Thanks again! Dave
Old 02-04-2009, 06:51 AM
  #178
VO...
Administrator
VO...'s Avatar
I would assume yes. The internal works of the door should not have changed. I'm not 100% sure, but about 99% sure. Give it a shot. The reset procedure is easy as pie. F the dealer. Those guys are crooks and always do shotty work from my experience.
Keep us posted Dave...
Old 02-09-2009, 11:25 PM
  #179
ISBA
ISBA's Avatar
Default Help with windows
I have an unusuall feauture in my 350z, The car was purked sudenly today i start the car and the windowns went all the way down automatically and i cannot move up, so shut down the car and i put the key on dorr **** and took the windows up manually. I tough thre problem was solve buit when i start my engine again windows went down again, its a rany day today i couldnt drive my car.
Its there any way to remove this feature or is it a failure of the eindow motor, does it happen this to anyone?
Please reply i need help i only have 1 car.
Old 02-10-2009, 07:49 AM
  #180
VO...
Administrator
VO...'s Avatar
It's not a window motor failure. It has to do with something else. I remember reading about it somewhere. I can not remember where though. Somewhere in this section. Something about a keyfob reset of something like that...
Quick Reply: How-To Repair Stuck / Broken Window Motor ...
