Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Maintenance & Repair
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 11-02-2008, 01:58 PM   #1
grudum
grudum's Avatar
Points: 2,584, Level: 30
Points: 2,584, Level: 30 Points: 2,584, Level: 30 Points: 2,584, Level: 30
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default A cry for help!! Z turns over but wont start
So I go out to get some starbucks this morning and the fuggin car wont start. It powers up all the accessories, and turns/cranks strong but doesnt give any signs of sputtering. Every other day, even last night it started with barely turning the key...like 1 or 2 cranks of the motor and it ussually fires up perfectly.
Why would it decide not to work today? I dont think I hear the fuel pump priming it anymore cause I dont hear anything now, so that might be it, but how can I check for sure while its in my driveway w/o towing it to the dealer.
I'm also thinkin it could be the ignition thing w/ the key chip...might have gone bad. is there anyway to check that?
I'm really trying to avoid the tow to the dealer at all costs any help is appreciated.
So far I've ruled out the battery starter and fuses.
thanks
grudum is offline   Reply With Quote
Old 11-02-2008, 02:04 PM   #2
Jarred@Z1
Z1 Motorsports
Jarred@Z1's Avatar
Points: 2,354, Level: 29
Points: 2,354, Level: 29 Points: 2,354, Level: 29 Points: 2,354, Level: 29
Send a message via AIM to Jarred@Z1
do you have another key? try that. If that doesnt help could be your crank sensor or throttle body any number of things you might want to see if you could get a scanner and check codes.
__________________
aim:JarredatZ1
Quote:
"My spelling is Wobbly. It's good spelling, but it Wobbles, and the letters get in the wrong places."
I brake for no apparent reason.
Jarred@Z1 is offline   Reply With Quote
Old 11-02-2008, 03:42 PM   #3
stealthz
stealthz's Avatar
Points: 2,427, Level: 29
Points: 2,427, Level: 29 Points: 2,427, Level: 29 Points: 2,427, Level: 29
Today's Activity: 0.7%
Today's Activity: 0.7% Today's Activity: 0.7% Today's Activity: 0.7%
how have you ruled out the battery? (just because you have a good voltage to the starter doesn't mean you have good cca's) is it the original battery? has the battery been hooked up and tested?
your alarm/ immobilizer could also be another key factor, when it doesn't decide to start on the first or second try use the key fob and lock the car again and than unlock it, than try again to start it... see if that helps
this link might help you....
http://my350z.com/forum/maintenance-...dnt-start.html
__________________
Good weather is getting annoying...
stealthz is online now   Reply With Quote
Old 11-02-2008, 05:43 PM   #4
grudum
grudum's Avatar
I dont have another key unfortunately. I'm going to try to get over to the dealer tomorrow to have them test the key I have..if they can even do that?
The battery is about a year old. I havent had any issues with it at all...its held its charge and the car has always fired right up. I havent hooked it up to a tester though...I will do this tomorrow.
I did try to jump start the car today and it had a wierd effect. With standard jumping proceedures the Z turned over slower and kinda chugged vs w/o the jumper cables. Seemed to have the opposite effect of what jumping a car should do. We then took the cables off and it cranked at normal speed. Can anyone explain this?
I have the battery disconnected now to try to reset the ECU...other than that I'm all ears.
Old 11-02-2008, 05:58 PM   #5
stealthz
stealthz's Avatar
there's a list of z's that have a recall on the crank angle sensor you might want to look into that... Has your car ever shut off on you randomly? how many miles are on your car? do you have an after market stereo or alarm hooked up to your car? and I assume you have no CEL? when that car gets started does it feel like it has full power or is it kinda sluggish? and if its your fuel sending unit or throttle body or clutch engagement switch you might not ever see a check engine light, but there could still be a code if your lucky and even then there's still not always a code... sorry for all the questions just more details helps....
__________________
Old 11-02-2008, 06:03 PM   #6
KPierson
Points: 5,037, Level: 45
Points: 5,037, Level: 45 Points: 5,037, Level: 45 Points: 5,037, Level: 45
Send a message via AIM to KPierson
You should be able to hear the fuel pump prime - if you can't start there.
However, the fuel pump prime is controlled by the ECU and it won't necesarrily prime each time you turn the key to the "ON" position.
After the car has sat for a bit turn the key to the "ON" position and listen. If you can't hear the fuel pump you can check the fuse to the fuel pump, or even pound on the fuel pump housing area a bit with a hammer and see if it turns on after that.
KPierson is offline   Reply With Quote
Old 11-02-2008, 06:06 PM   #7
THE ROADSTER
THE ROADSTER's Avatar
Points: 3,171, Level: 34
Points: 3,171, Level: 34 Points: 3,171, Level: 34 Points: 3,171, Level: 34
Check the fuse for the fuel pump. It happened to me once and the fuse for the fuel pump blew.
THE ROADSTER is offline   Reply With Quote
Old 11-02-2008, 06:36 PM   #8
grudum
grudum's Avatar
The car has run at optimal performance...no sluggsish anything, never randomly shut off, has a smooth idle, as of last night there were no CEL's thrown to indicate an issue.
I'm not hearing anything out of the fuel pump. I turn the key to "on" and the gauges come alive, but i dont hear anything else...silence...maybe a slight "tick" but nothing weezing or anything that sounds like its doin anything.
Is the fule pump fuse in the lil fuse box in the battery compartment or another location? Where is the fuel pump located to tap it with the hammer? is it on the outside of the tank?
I took the intake off and felt inside the throttlebody just after trying to start it, and it was wet, (and dirty-will clean soon )
I just tried jumping it again and this time it turned over at a normal speed, so I might have had a bad connection earlier....still didnt start though.
I locked and unlocked the doors several times with no luck. Still stumped. I'll look into that recall.
Thanks for the input so far...its still a mystery.
oh ya..car has 96K miles, 6 speed. Has run flawlessly for years until this morning...even yesterday. I'm guessing something electrical decided to take a schit cause it ran perfect yesterday.
Old 11-02-2008, 06:56 PM   #9
stealthz
stealthz's Avatar
are you using a factory battery? and have you actually got to drive your car at all since you've gotten it started or have you just let it idle? with that many miles I would check ignition coils as a possible factor? have your sparks plugs been replaced? was there any oil inside the spark plug chamber? did you wash your engine bay recently...
__________________
Old 11-02-2008, 07:03 PM   #10
grudum
grudum's Avatar
Quote:
Replaced about 1 yr ago.
I put about 100 miles on it yesterday runnin around town. stoppin at many stores and it started w/o a hitch...no issues yesterday.
I'll add this to the list.
15Kmi ago. everything *should be* A -ok w/ them.
was there any oil inside the spark plug chamber? Dry.
Nope.
hmm...
Old 11-02-2008, 07:13 PM   #11
KPierson
The fuel pump is located in the little compartment behind the passenger seat. if you open up that compartment you'll see a little circular square cover (not really a circle, not really a square). That panel detaches and the entire fuel pump assembly pulls straight up.
I had a buddy who got stranded because his fuel pump wouldn't turn on. We tapped it a few times and it started up like nothing had ever happened.
Old 11-02-2008, 07:29 PM   #12
stealthz
stealthz's Avatar
Ok if I were you I would...
1. would look up your VIN to see if it falls within the faulty crank angle sensor that nissan put out
2. Test the battery
3. hook up a scanner anyways, you still might have a code without a check engine light
4. check both sides of the fuel pump fuses for power when the car is in the on position... If your fuel pump is primed you won't hear anything... but the sending unit goes out from time to time... so test out the sending unit
5. check your coils out
6. reset the battery
7. take it to a dealer so they can inspect your key and make sure the immobilizer is reading it, and alarm is working correctly.. and so they can check your throttle body out... and maf sensor
__________________
Old 11-02-2008, 07:53 PM   #13
grudum
grudum's Avatar
Stealthz...looks like a good plan of attack along with checkin the fuel pump.
For your viewing pleasure here's the current state of affairs...
After watching this....the fuel looks low, but I just put in a half tank yesterday, so that shouldnt be an issue.
Old 11-02-2008, 08:04 PM   #14
tecni
tecni's Avatar
Send a message via MSN to tecni
check out the crank angle sensor. Although the car should still start even if its unplugged but only after a few seconds of cranking
tecni is offline   Reply With Quote
Old 11-03-2008, 06:40 AM   #15
grudum
grudum's Avatar
Morning update:
So this morning the car just clicks - indicating the battery. Wierd cause yesterday the batt seemed fine and even while jumping, the car it still didnt start. Is it possible that even w/ a jump that a car wouldn't start due to the battery?
How/Where is this thing?
Old 11-03-2008, 07:19 AM   #16
KPierson
It doesn't sound like a battery issue to me - you probably just drained the battery cranking it so many times.
The crank angle sensor is under the car towards the back of the motor. If you jack the car up and slide under it the crank angle sensor is accessible. It has a three wire plug going to it and if I remember right is the only sensor that is directly on the bottom of the motor.
Old 11-03-2008, 05:59 PM   #17
guitman32
guitman32's Avatar
Points: 2,644, Level: 31
Points: 2,644, Level: 31 Points: 2,644, Level: 31 Points: 2,644, Level: 31
Today's Activity: 15.0%
Today's Activity: 15.0% Today's Activity: 15.0% Today's Activity: 15.0%
+1 that battery sounded strong in the vids. When my 1st battery went my starter sounded tired as can be, but I didn't notice since I drove the car for a while on a low battery (without issue). Once I replaced the battery, the difference was huge (my starter sounds like yours does now)
__________________
SB.Track.JWT.Enkei.Motordyne.Nismo.Hotchkis.Koni.RS*R.PMu.St optech
guitman32 is offline   Reply With Quote
Old 11-04-2008, 07:26 AM   #18
grudum
grudum's Avatar
Morning update...
I took the battery into autozone for a test and it was at full power. Max charge. So as a few of you have stated...thats not the problem. I also picked up a OBD2 tester to see if any codes are thrown. No codes. Scanned it a few times just to make sure and it was clean...so no hints there.
I also picked up this little gadget thats an "imitation spark plug" to plug into a sparkplug coil and it will arc between 2 needles if the spark is getting to the plugs...It was dark by the time I was ready to deal with this lil toy, so I'll fiddle with that tonight.
I also picked up a spray can of ether aka "starter fluid". Can someone tell me if its a bad idea to spray this into the intake to see if the car fires up for a second? I dont know how our cars respond to this type of persuasion. Will this mess up a sensor somewhere? If not what is the best way to do this? Take the filter off and spray before air sensor, or take off the whole tube and spray into the throtttlebody area?
The thought being, that if it fires up w/ this method, then i know spark is alive and fuel is the issue. Then I can dig for the fuel pump. My pop's warned that doing this can create a backfire of sorts and is kinda hard on the car, so I dont know if anyone has tried this on a modern car. Please lemme know.
I called the dealer and they cant check my key w/o the car there too...so thats out until I pony up for the tow.
I think one more night of tinkering w/ it and I will have exhausted the driveway diagnostics and may have to tow it to the stealership.
Oh ya...I didnt find a fuse labled for the fuel pump...where exactly is that lil bugger. thx
Old 11-04-2008, 09:00 AM   #19
cracka350z
Points: 3,039, Level: 33
Points: 3,039, Level: 33 Points: 3,039, Level: 33 Points: 3,039, Level: 33
Send a message via AIM to cracka350z Send a message via Yahoo to cracka350z
mine is doing the same thing sortof...it sometimes starts but then sometimes it doesnt. ill crank it then take the key out and wait for a few....then ill try again (and again till it starts) but im getting the sluggish stuff when i drive. like it has no power. i got passed by an HHR on the freeway could all this be the Crank angle Sensor?
ps...not trying to jack the thread but im in the same boat and as far as the spraying the ether in there...i would say NO lol. old carbeurated cars maybe but not one with all the electronic crap.
__________________
1998 toyota aristo - gt4082, built motor, built trans (in progress) 516hp@1.3 bar
cracka350z is offline   Reply With Quote
Old 11-04-2008, 08:33 PM   #20
grudum
grudum's Avatar
Conceding failure ...allowing the dealer to take over. Will post once the dreaded phone call comes in tomorrow.
btw...i would not recommend using a tow dolly for a car that wont start...its a bich to get it on there. Never again.
My350Z
350 Z
Paid Advertisement
Tags
2005, 350, 350z, barely, car, causes, crank, cranks, fire, my350z, nissan, overfiresbut, start, turns, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
