puddle on passenger side floor
on
underneath the carpet in my car there is a hole with a rubber gromet (similar to the door hadle belt covers). i do not know if this is something every z has or just mine, but that may be the problem. its underneath the carpet so it may be a little difficult to investigate on just a hunch.
on
I know this is a old thread but I have the same problem, everytime it rains and I drive my car the driver side carpet gets soaking wet. I pulled uout my floormat and every inch of the carpet was drenched, I guess I am pulling out my carpet this weekend to find out whats up lol.
on
I figured out my water issue yesterday, I pulled off the wiper cowl & two covers on the sides and noticed that the grommet pulled off on the driver side where my water leak was. Who ever had my car before me put a system in it and ran the power wire though it so I just put a slit in the grommet and a small hole for the wire to fit through. I used some black silicone to seal up the slit that I made and to inside, outside of the hole, all around the wire, all the way around the edge of the grommet and firewall so that bad boy should not leak again LOL.
on
I'm having the same problem on my 03. I thought it was probably the AC drain but everyone says that will leak on the passenger side. I'll look at it this weekend if ti does not drain. Do you have any pics?
Anyone have any good links to other sources of water in the driver foot well?
CFAUVEL
10-01-2015 03:20 PM
