Window Motor repair, they can be fixed!
Old 09-13-2010, 06:19 PM
  #61
bswanny
bswanny's Avatar
What is the brush part number? I look up 540 motor, upright brushes, uncut and get nothing. Could you tell me what the number is on the Trinity package? Thank you
Old 09-15-2010, 08:47 AM
  #62
paradigm79
paradigm79's Avatar
I'm not sure what others used but I rebuilt mine with Trinity 4500NT (NT = no terminal but 4500 is fine, just cut off the terminal). I don't know how the 4500 wear rate will compare to the stock brush. As a side note, I only had lay down brushes and they can be made to work but it took a little sanding/fiddling.
Only thing I would add to the instructions is the suggestion to make alignment marks on the armature shaft and motor housing so you can slide it back in exactly as it came out. With one motor I had no trouble, but the other I fiddled with it forever trying to get it back in, many beers later I rotated it just right and it dropped right in.
Old 10-14-2010, 08:47 PM
  #63
350Track03
350Track03's Avatar
Reseting black button while moving window up and down fixed my passenger side window.
Old 10-15-2010, 01:59 PM
  #64
Armed Ferret
Armed Ferret's Avatar
Anyone else's window louder after doing this? Mine sure is.
Old 10-15-2010, 02:28 PM
  #65
BoomerZ33
BoomerZ33's Avatar
like squeaky loud?
Old 10-22-2010, 02:07 AM
  #66
assfault
assfault's Avatar
im having a problem putting the internal spinning part back in, its off about an 1/8th of an inch, like something is keeping it from going all the way in
Old 10-22-2010, 06:41 AM
  #67
Armed Ferret
Originally Posted by BoomerZ33
like squeaky loud?
yeah, a low-pitched squeaky. almost sounds like it's groaning as it goes up and down.
i have to remove the panel this weekend to reset the motor (somehow lost its reset last time when i replaced the brushes), so i figured if there's a way to quiet it down i'll do so.
although i'm not going to sit and wait for a reply; imma go search.
ETA: after reading a few threads that came back from search, I don't think i'm having the same issue. It's basically the same sound of the window going up and down, just louder is all.
Old 10-22-2010, 12:59 PM
  #68
ttbbsolid
ttbbsolid's Avatar
I did notice the louder motor noise after fix.
But the thing is, now I have this ticking noise when window is fully closed and when it's almost closed.
Maybe I've tightened those rail to door panel nuts too tight??
anyone experiencing this ticking / rattling noise ?
Old 10-24-2010, 09:41 AM
  #69
binder
binder's Avatar
i have on ticking or rattling or odd noises. It did get a little big louder but only over the old dead brushes when the motor wasn't turning very fast. It's faster now and slightly louder than before but it's the same volume that my "good oem" passenger side is.
Old 10-24-2010, 09:42 AM
  #70
binder
binder's Avatar
oh ya, the ticking or poping is usualy the window regulator. I think they are about 50-75$ through nissan/infiniti. The regulator is all the cables and pulleys. I had to replace mine before my motor went out cause it was popping and studdering when it was going up.
Old 10-25-2010, 08:34 AM
  #71
ttbbsolid
ttbbsolid's Avatar
Thanks Binder.
oh man.. looks like I need to spend more money for the window.....
Hope I can gain like 50 HP changing the regulator.
Old 10-25-2010, 11:30 AM
  #72
Armed Ferret
Originally Posted by ttbbsolid
Thanks Binder.
you can if you put some stickers on your ride.
Old 10-26-2010, 07:57 AM
  #73
binder
binder's Avatar
Thanks Binder.
fix it before it breaks. When it breaks window falls and stays down unless you tape it up which is hard to do since you have to open the door to get out.
Old 10-26-2010, 09:01 AM
  #74
ttbbsolid
ttbbsolid's Avatar
uh oh...that doesn't sound so fun...
I guess I will just change both sides since mine is MY03...
Thank you for the tip!
Old 11-20-2010, 04:36 AM
  #75
"doc" schrage
"doc" schrage's Avatar
both mine are down..... window regulator on pass motor on driver... HML! im gonna give this a try for sure
Old 11-20-2010, 11:41 AM
  #76
"doc" schrage
I got
Old 11-20-2010, 07:31 PM
  #77
binder
binder's Avatar
yep, it'll save you a ton of money if you can get in there and do this.
Old 11-24-2010, 07:57 AM
  #78
hottoddyo
hottoddyo's Avatar
Can you elaborate on this some more. How do you reset using the black button? My window works sometimes, I have to push it down to make it work. Not sure if this will work for me or not, but I'm willing to try it.
Old 11-26-2010, 09:53 AM
  #79
binder
binder's Avatar
search on here for "window reset procedure". It's in the service manual.
If you had to physically move your window to get it to go down then it has nohting to do with the window reset. Window reset just resets the motor to know what is the fully up and fully down position of the window. It will not fix any problems. It's needed after installing a new motor or fixing an old motor and reinstalling it.
Old 03-17-2011, 01:52 PM
  #80
tblunt1
tblunt1's Avatar
Anyone have a link on where they ordered the brushes? The closest RC hobby shop is around 45-50 miles so I'd burn way more in gas than just ordering them off the web.
Tried googling and all I get are some forum posts on hobby sites a couple years old, of course I've really no clue exactly what I'm looking for other than "540 upright brushes" lol.
Thanks!
*EDIT*
Never mind, I'd forgotten about Ebay! "If" they are the correct ones I just got 5 sets for 7.57 shipped.
http://cgi.ebay.com/NEW-540-size-mot...item3a6349ee68
Quick Reply: Window Motor repair, they can be fixed!
