You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hello fellas. I am having issues starting up my Z. When cranking the ignition, seems like there is not enough juice to crank up the starter. I don't think its a battery issue. The voltage reads the same as always and all lights are working fine without any dimming. I'm thinking it could be the spark plugs. This car already has 59,000 miles and had never changed the spark plugs or even had a tune up. Could this be the issue?
Any help out there would be greatly appreciated. Thanks!
__________________
2005 Track Z33 PPW:Tein Type Flex ~ more to come...
__________________ Team Nextstage
Sponsored by Meguiar's, Imported Performance www.teamnextstage.com Team DNF n00bslayer & eater of children............................................................ ...............
just go with an interstate battery or if you want a expensive high maintenance battery go with the solid state one( nothing but problems god forbid it gets cold out). Your problem does sound like a battery, a battery can put out the correct voltage, but not the right amp. Spark plugs are not like they use to be an old carburated car would need them changed about every 20k EFI cars about every 100k. go the cheap route get to autozone and have them check it for free or it you have an ammeter you can do it
+1....
my money is the autozone battery tester will confirm your battery is da dead...
-J
__________________
04 PPW Touring - My favorite mod is my short Dodge Avenger antenna
thanks for all your help. I will check out autozone tonight.
Could it also be the alternator?
if once the car starts and it stays running... doubt it like i said before go to autozone it is a gauge that will determine the integrity of the electrical system and it is a free service, contrary to most cars, the Z's volt meter gauge is quite accurate in telling you the current charge or discharge of the system
Thanks qqqqball. You were right. The battery was at the end of its life. Got a new Duralast battery and car starts and run with no problem. Appreciate everyones help on this.
__________________
