Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Maintenance & Repair
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 11-16-2009, 11:50 PM   #1
ZeeYa
Default reverse light wont work
need help my revers lights wont come on at all, all other lights work fine even turn signals work as well, any suggestions?
thanks
ZeeYa is offline   Reply With Quote
Old 11-16-2009, 11:56 PM   #2
SatchScream
Points: 1,206, Level: 19
Points: 1,206, Level: 19 Points: 1,206, Level: 19 Points: 1,206, Level: 19
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Fuse?
SatchScream is offline   Reply With Quote
Old 11-17-2009, 12:10 AM   #3
ZeeYa
Quote:
Originally Posted by SatchScream View Post
Fuse?
didnt see any for the reverse light in fuse box...
unless im blind...
04 6spd...
Old 11-17-2009, 06:50 AM   #4
Paul350Z
Living in 350Z
Paul350Z's Avatar
Could also be the tiny sensor switch that detects when the shifter is pushed into reverse.
Inside the IPDM (Intellegent Power Distribution Module) in what Nissan calls the Engine Room (under the hood!) fuse #71 is for the backing lights, it's a 10A. From there the circuit runs to relay E19 which is controlled by that switch I mentioned - and provides power to the two backing lights.
Fuse location (#71 upper left corner)
Back-up relay location (the area in the diagram is near the battery)
Circuit Diagram
__________________
Super Black 2005 35th Anniversary
Paul350Z is offline   Reply With Quote
Old 11-17-2009, 10:01 AM   #5
burner
burner's Avatar
Send a message via AIM to burner
Funny story...mine went out and the dealer said my IPDM was bad. The car wouldn't start either, but if I push started it, it was fine. Had them replace it @ $1000. Got curious and started poking around, and found that it was that fuse mentioned above. Long, long story short I threatened to sue the dealership and they refunded my money. If your car starts and the lights are your only problem, I bet its your relay and not the fuse.
__________________
UpRev Tuned : Volk : Nismo : Tein : Powerlab : K&N : TurboXS : Pioneer : Alpine
burner is offline   Reply With Quote
Old 11-17-2009, 12:38 PM   #6
ZeeYa
thanks for the help guys, first thing ill do when i get off work is check it out see if i can find the problem....
the last diagram looks like hieroglyphics to me... :/
thanks again guys!
Old 11-21-2009, 05:38 PM   #7
ZeeYa
damn it...
i looked at the #71 fuse, and it was good.....
back up lamp relay seems to be good, my mom has a frontier i switched out the rev lamp relay and still no back up lights......
Old 11-22-2009, 02:35 AM   #8
nightcrawler_8
nightcrawler_8's Avatar
Points: 3,356, Level: 36
Points: 3,356, Level: 36 Points: 3,356, Level: 36 Points: 3,356, Level: 36
check the switch in the gear box itself
i had the same issue and found out the switch on the gear box itself was gone bad.
it was 30$ fix.
good luck with it.
__________________
GTM TT Stg 2 ... under Construction...
nightcrawler_8 is offline   Reply With Quote
Old 11-22-2009, 04:15 PM   #9
ZeeYa
it was 30$ fix.
good luck with it.
any tips/ instructions?
Old 11-22-2009, 10:21 PM   #10
nightcrawler_8
Quote:
on the gear box case itself, next to the gear mounts. there is a blue switch that controls the reverse light. if that one is damaged then you wont get the rear light to work.. its a simple fix.
check the pic below: forget about the part number. this is for another car, but its the same concept.
__________________
Old 11-22-2009, 11:52 PM   #11
ZeeYa
so this means it would be better if i put the car on stands?
Old 11-23-2009, 02:14 AM   #12
nightcrawler_8
u wont be able to remove it unless u take the whole car up...
__________________
Old 11-25-2009, 10:05 PM   #13
nightcrawler_8
hope it worked out well with u ....
__________________
Old 11-26-2009, 12:02 AM   #14
ZeeYa
order the switch today. hope that does it...
Old 11-26-2009, 10:36 AM   #15
vthao
Points: 2,572, Level: 30
Points: 2,572, Level: 30 Points: 2,572, Level: 30 Points: 2,572, Level: 30
have you checked the bulbs?
__________________
4.08 FD l Eibach l ROTA l JWT l MotorDyne l Brembo
[SIGPIC][/SIGPIC]
vthao is offline   Reply With Quote
Old 11-30-2009, 11:39 PM   #16
ZeeYa
Quote:
lol nope, switch should come in tom...
Old 12-01-2009, 12:27 AM   #17
nightcrawler_8
you must be kidding,,, u didnt check the bulbs ?!!!!1 why !!!
that should be way easier.. cause if its just a bulb then u wont need the swtich.
__________________
Old 12-06-2009, 11:52 PM   #18
ZeeYa
lol... will do it tomorrow... i just got the switch in too lol
Old 12-13-2009, 09:54 PM   #19
rockinbboy
rockinbboy's Avatar
Points: 4,456, Level: 42
Points: 4,456, Level: 42 Points: 4,456, Level: 42 Points: 4,456, Level: 42
Today's Activity: 1.1%
Today's Activity: 1.1% Today's Activity: 1.1% Today's Activity: 1.1%
I had a problem with no reverse lights. I also had no cruise control and SES light at the same time. error code said netrual assembly switch or something. turns out some rodents (I suspect a groundhog) had chewed some wiring underneath the car which caused my problem. Check the wiring underneath and the associated switch that someone posted earlier.
__________________
2006 Daytona Blue Enthusiast 6 speed: Bone Stock as of 02/16/2006 K&N Drop In as of 06/6/2008 Eagle F1 All Seasons as of 06/21/2008
rockinbboy is offline   Reply With Quote
My350Z
350 Z
Paid Advertisement
Tags
350z, back, backup, frontier, fuse, g35, ipdm, lamp, light, located, location, nissan, relay, replacing, reverse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
