You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
just swapped the engine on my 05 350z. engine came out of an 04. kept original harness and original ecu.
1st day everything fine. 2nd day check engine light went on with these codes.
1:P0605 POWERTRAIN CONTROL MODULE READ ONLY MEMORY (ROM) ERROR
2:SAME AS ABOVE
3:P0113 INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT HIGH INPUT
4:P0183 FUEL TEMPERATURE SENSOR A CIRCUIT HIGH INPUT
the car drove fine. since the check engine light is on no response the throttle pedal.
with these codes could the engine have mods and the ecu needs to be reprogrammed?
...I would first ask if you had a rev-up ( 35th anniv. car ) and swapped in just a DE... I would imagine there would be some plugs that did not have anywhere to go and vice-versa.... and then also the most simple thing would be a bad sensor????
__________________
RIP'06 Black Z • Power Enterprise • AAM • APS • DoLuck • Master Grade • Volk
its not the 35th anniv. which sensors u think i should look at? its weird cuz the car drove fine and just out of nowhere the cel came on.
i just noticed that these two codes are pending.
the first two i tried deleting. success but after the first start they come back one. and im guessing that 3 and 4 are still pending in the ecu. what could it be? any ideas?
wow you guys wont believe this. last night my sister had my car. calls me and tells me, theres no response to throttle pedal.
so i check the code today same crap again. replaced the maf sensor again. deleted the codes but p0605 wont delete.
