Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Maintenance & Repair
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 12-01-2009, 11:06 AM   #1
grudum
grudum's Avatar
Points: 2,584, Level: 30
Points: 2,584, Level: 30 Points: 2,584, Level: 30 Points: 2,584, Level: 30
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Default Reverse lights on all the time
I have an 03 and this just cropped up and I've tried all the ussual suspects.
I looked at the options laid out in this thread/post and nothing solved it so far.
http://my350z.com/forum/maintenance-...wont-work.html
Quote:
Originally Posted by Paul350Z View Post
Could also be the tiny sensor switch that detects when the shifter is pushed into reverse.
Inside the IPDM (Intellegent Power Distribution Module) in what Nissan calls the Engine Room (under the hood!) fuse #71 is for the backing lights, it's a 10A. From there the circuit runs to relay E19 which is controlled by that switch I mentioned - and provides power to the two backing lights.
Fuse location (#71 upper left corner)
Back-up relay location (the area in the diagram is near the battery)
Circuit Diagram
I pulled the #71 fuse and the lights were still on, but then the car didnt start, so I dont think that fuse is the same for an 03. I continued to pull all the other 10A fuses and none of them turned the lights off. I then looked for the reverse light control module (from the second diagram (E19) and there isn't one in my car. Its a manual tranny. I've flip flopped the connections on the tranny to see if that would fix it, but nothing. They are still on. Does anyone have any other idea's.
I've pulled the bulbs for now, but would like to get this solved.
grudum is offline   Reply With Quote
Old 12-01-2009, 11:32 AM   #2
Skeefy
Points: 1,067, Level: 17
Points: 1,067, Level: 17 Points: 1,067, Level: 17 Points: 1,067, Level: 17
I don't have a an FSM for an 03. But you car must have both the TCM and the (19) relay. Since both of you lights are working, power is getting through the relay (19). I'm guessing it is a bad TCM sending power to the relay.
__________________
07 / Touring / Auto / Pikes Peak White
Skeefy is offline   Reply With Quote
Old 12-01-2009, 11:45 AM   #3
grudum
grudum's Avatar
Quote:
Cool. Where is that thing located? Is it on the tranny?
Old 12-01-2009, 12:23 PM   #4
cheshirecat79
cheshirecat79's Avatar
cheshirecat79
Points: 5,147, Level: 45
Points: 5,147, Level: 45 Points: 5,147, Level: 45 Points: 5,147, Level: 45
Today's Activity: 35.6%
Today's Activity: 35.6% Today's Activity: 35.6% Today's Activity: 35.6%
Send a message via AIM to cheshirecat79 Send a message via Yahoo to cheshirecat79
is the car in reverse
cheshirecat79 is online now   Reply With Quote
Old 12-01-2009, 05:35 PM   #5
Skeefy
It must be in, or on, the tranny. Typically reverse lights are activated by the shift lever when the car is put in reverse. I'll look at my FSM and see what I can find.
__________________
Old 12-01-2009, 06:01 PM   #6
Skeefy
My FSM shows the reverse light switch on the driver side, at the back of the tranny, and forward of the shift lever. With the car in neutral, pull the wires off the switch. If the reverse lights go out, it is the switch. You can also check the continuity of the switch with a multi-meter. If there is continuity, with the car in neutral, it is the switch.
__________________
Old 12-02-2009, 03:54 PM   #7
grudum
grudum's Avatar
Awesome! Thank you. I'll try that next and report back.
My350Z
350 Z
Paid Advertisement
Tags
2003, 350, 350z, box, circuit, fuse, fuses, g35, infiniti, ipdm, light, lights, located, nissan, reverse, time, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
