Nissan 350Z Discussion forums, Photo Gallery and more...
Go Back   MY350Z.COM Forums > 350Z Tech Area > Maintenance & Repair
Sign in using an external account
Register Forgot Password?
MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Welcome to my350z.com!
Welcome to my350z.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Thread Tools Search this Thread
Old 12-03-2009, 02:50 AM   #1
red_2003_Z
Default missing then not whats up
so i took my car in about 500 miles ago while it was there they replaced the plugs car ran great for the first 500 miles then out of no where it started mising like one cylinder was not firing ses light came on then started flashing then back to solid started the car next day and ran fine ses still on solid then had the same problem for about 30 seconds several times through out the day but is fine now. any ideas why it would come and go? when coil packs fail to they wear out slowly like this? it has been my experoence that they fail and stop working all together. i will double check that they are all seated correctly but that dosnt seem like it would be the case. i would appreciate any ideas or thoughts
red_2003_Z is offline   Reply With Quote
Old 12-03-2009, 04:02 AM   #2
bluelineshooter
bluelineshooter's Avatar
Points: 1,347, Level: 20
Points: 1,347, Level: 20 Points: 1,347, Level: 20 Points: 1,347, Level: 20
Today's Activity: 0%
Today's Activity: 0% Today's Activity: 0% Today's Activity: 0%
Your Z is totalled. You must get a new one. Sorry
bluelineshooter is offline   Reply With Quote
Old 12-03-2009, 07:28 AM   #3
red_2003_Z
i knew it! thanks
Old 12-03-2009, 08:20 AM   #4
GT-Z
Points: 1,399, Level: 20
Points: 1,399, Level: 20 Points: 1,399, Level: 20 Points: 1,399, Level: 20
Today's Activity: 0.4%
Today's Activity: 0.4% Today's Activity: 0.4% Today's Activity: 0.4%
a wire could be loose. but thay only seat one way less thay didnt put the screw back in. check and make sher ur coils are all pluged in then take ur battery cable off for 5mins put it back on then see what happens
__________________
2004.5 Enthusiast, Stillen-Nismo-Nitto-K&N-Pioneer D3
GT-Z is offline   Reply With Quote
Old 12-03-2009, 10:31 AM   #5
ms350z
ms350z's Avatar
Points: 1,472, Level: 21
Points: 1,472, Level: 21 Points: 1,472, Level: 21 Points: 1,472, Level: 21
Well, the first step is to have the code pulled. Most auto parts stores will do this for free. I am almost certain you are getting a P0300 multiple/random misfire code if your CEL is flashing. DO NOT drive your car if you are getting a flashing CEL if you can help it. This means that a lot of unburned fuel is being dumped into your cats and will destroy them pretty quickly. Most likely a coil has gone bad or come unplugged, but it could be a range of things causing this such as a vaccuum leak. In any case, the next step is to PULL THE CODE and let us know what it is.
ms350z is offline   Reply With Quote
Old 12-04-2009, 11:03 PM   #6
red_2003_Z
well im stationed in germany andim wondering if cold weather could have been an issue i know its unlikely but the ses cleard it self and no more misfire unfortunatly i dont speak german and it takes a few days of research for me to find any type of shopwhere i can take my car and i deploy in 4 days so it looks like it will have to wait another thing is i dont think the plugs they ordered were plainum tip like the dealer recomends so i will probably replace them as soon as i get back thanks for the help i also have berk hfc are they more subject to being damaged by the extra fuel not being burned its seems the opposite would be true?
My350Z
350 Z
Paid Advertisement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
ADVERTISING
INSURANCE CENTER
Advertise on MY350Z.COM - MY350Z.COM - Archive - Top
Advertise on MY350Z.COM - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Copyright ©2002 - 2008, MY350Z.COM All Rights Reserved.
Admin control Panel Backup
