Random Misfire. P0300
on
It's a bad fuel injector. It should be closing before the valve but it can't and the fuel it sprays bounces off the closed valve and blows up into the plenum and gets sucked in by the other cylinders. The engine senses the overly rich condition and thinks it's misfiring and throws a PO300. Pull all your spark plugs and inspect them one by one. Whichever is carbon fouled, that's your stuck injector, change it.
on
I have had a random misfire code for quite a while now> p0300. I have recently done all of the following.
-New coil packs
-New spark plugs
-Replaced all 6 injectors
-Valve Cover gasket
-RTV the plug well seals to stop the oil from getting into cylinder
-Even did a new PCV just in case there was bad pressure.
Any other suggestions on what could be causing the problem? My car has full throttle up until about 4k RPM then falls on its face and literally does have any *** passed that> And running extremely rich.
2004 350z
-New coil packs
-New spark plugs
-Valve Cover gasket
2004 350z
-New coil packs
-New spark plugs
-Valve Cover gasket
2004 350z
-New coil packs
-New spark plugs
-Valve Cover gasket
2004 350z
ever find out? Lolol needs to knowww
350Z/370Z Tech Moderator
This is the sixth time this week. People, check the dates of the posts you’re tempted to ask questions about. This post was the last time (likely their first and only time) they posted here.
Net net, don’t expect an answer.
I checked the date, taking a random stab. Don’t see the harm done bucko
-New coil packs
-New spark plugs
-Valve Cover gasket
2004 350z
-New coil packs
-New spark plugs
-Valve Cover gasket
2004 350z
i've been trying to fix the same exact issue on my friend's car
i've done:
6 new injectors
intake manifold gasket set
new MAF
knock sensor
knock sensor harness
crank sensor
6 new spark plugs
on
AbyteZero
09-22-2015 09:17 AM
