vdc off & slip light? HELP :(
on
awesome, I'll add it to my list, thanks.
I'm still having issues starting the car after the tires have been changed. Would the cam sensors need resetting or something?
Bumping instead of making new thread.
Swapped out my front lower ball joints, sway bar end links and inner and outer tie rods, and 1 inner tie rod( old one was damaged)
I did not have issues with my tire size combo for 5 years so I don't think that just randomly cause this. After the install and doing a quick test drive VDC and Slip lights turned on. They only turn off when the car is turned off but come back when I drive the same distance.
I measured the threads and length of the tie rods so
my alignment wasn't complete trash. Could this be cause because the car isn't aligned yet?
I did the usual checking of fuses and brake fluid level so nothing appeared out of order and prior to this nothing was wrong with the car, or the sensors.
any ideas?
any ideas?
