Weatherstripping rotting, need help for replacement part!
on
Hey guys, been browsing the forums for years and just finally decided to join because I can't seem to find the information I need anywhere.
The weatherstripping on my windshield, in the corners only, is disintegrating and I need to replace it.
Anybody know the exact name, part number or even better can link me to the part itself on an online store?
Thanks in advance!!
-marc
Thanks in advance!!
-marc
on
I would guess there is a way to find the rubber trim they use and simply glue it ourselves, the tricky part is the bottom when it gets wider... Anybody tried this in the past? Terrible mistake or doable?
Spending over $600 to replace pillars that are completely fine just to fix a silly rubber trim... I dunno, hard to justify it to myself.
I'll try to open it up sometime this week and and post photos... see how this thing is made -_-
on
This is where your wrong my friend. It actually DOES seal off from water entering into the cabin area. In fact, Im about to seal off that area with some black silicone, when it rains hard, or when Im driving into the hard rain, or going thru a Car Wash, the water gets in that crack and drips at the top of the Tweeter Plastic part, and even gets pushed up top along the weatherstripping around the window and starts dripping there too. Want to know why? BC my passenger side windshield rubber strip is completely gone, and it drips pretty good when I wash my car, I have to spray that area pretty fast. Screw it, Im doing a bead of black slilicone this weekend. It'll look factory if you do it right.
on
Any advice on repair or method if using a sealant? My car is leaking water into my cabin through these POS rotted weatherstripping. Not sure if you can seal up from inside and/or outside also. Thanks! Pictures appreciated.
I had them replaced TWICE due to installer incompetence, The first time they damaged them taking them off, and installed a green tinted window. When I insisted they install the blue tint the car had it was revealed he had glued them in so they got to pay for another set.
