OEM HID problem I can't figure out, Please Help.
on
Ok to start off I have a 2003 touring edition, the oem hid's have had a problem for the past couple months and I cant figure it out. When i first turn them on they both come on and then the drivers side light flickers and then turns off. Sometimes if i leave the headlights on for 20 or 30 minutes then turn them off and back on real fast they will both stay on, but only occasionally does that work. I bought a new ballast last week off ebay (the same type ballast from the same seller as a member here recommended in another thread). I replaced the ballast and the next day it is doing the exact same thing. I do not think it is the bulb becuase the bulb actually comes on before it flickers and goes off, and i do not think its the ballast because i replaced it. Does anyone know what it might be?
on
ok to check the connections i unhooked everything, put it all back together and then switched the bulbs sides, then everything worked all together. But after a few days the passenger side started messing up so i assumed it was the bulb, then a couple days later they would both flicker out so im going to order new bubls just to see if that fixes it.
liqalu04
01-02-2022 12:58 PM
CFAUVEL
10-01-2015 03:20 PM
