Car feels extremely unstable going in a straight line
Old 07-30-2013, 02:39 PM
  #101
Bmurray350z
Bmurray350z's Avatar
Originally Posted by labelworkshop75
Be sure to inspect the bolts/washers and look for play. Post 19 of suspension 101 thread (attached) has pics of what to look for. Also be sure to let the alignment tech know to take it easy on the toe bolts. If he is going HAM on them, they will deform.
Yeah I quote exactly what the alignment tech said "most people we don't tighten these toe bolts as much as we will yours because we know you probably beat on your car a little"
so i will tell him to just do the normal.
so you think when i put the new suspension on, it was just more noticeable than before? because like i said, before the wheels/tires, coilovers, and spc a arms, i did not have the problem whatsoever and i was on tanabe springs with stock shocks, still had the spc rear arms and toe bolts. but was not experiencing any of this..?
Old 07-30-2013, 03:12 PM
  #102
labelworkshop75
labelworkshop75's Avatar
Most likely they stripped the washer on your first alignment. They aligned it again and got it into spec, but since the washer is now deformed as soon as you drive the car it will come out of spec due to the play in the washer from it being stripped. Post detailed pic of your washer, and bolt in the washer. You will see a few degrees of play. Play = BAD.
Make sure they take it easy on those bolts. It does not take much to screw them up.
Picture of mine below:
Old 07-30-2013, 03:20 PM
  #103
Bmurray350z
this is what im saying though...
1. Car was 100% normal, didn't feel like this at all.
2. Put car on jackstands for about 2 weeks
3. installed coilovers, spc front a arms, and new wheels/tires over the course of the 2 weeks.
as soon as i put it on the ground and drove away, it was doing this. so i figured it was the alignment. got it aligned and the problem persists, and hasn't went away since.
the toe bolts weren't touched over the course of 2 weeks while i was waiting on the parts to come in and install them..
hope you understand what im saying?
Old 07-30-2013, 04:35 PM
  #104
labelworkshop75
Well, one thing you know for certain is that something is causing your car to not hold an alignment. Your second alignment "original" readings were very poor. Especially front toe.
I would consider slowly going back to stock and see if you can catch the problem that way. Maybe you have a faulty part?
One thing I noticed in the first pic. Are your tires mounted correctly. Looks like one of the "directional tread patterns" is facing one way, and the other tires pattern is facing the other.
Also since this is the first time your car has been "low" you may have torn a bushing. Once you lower the vehicle you put much more stress on these linkages.
Leaning away from toe bolt issue now.......
Just throwing out ideas now.
I didn't realize how off your front toe was on your second alignment.
Old 07-30-2013, 04:38 PM
  #105
Bmurray350z
yeah well front toe would be out because i fcked with the preload on the front coilovers to try and fix the problem.. so it probably threw it out of spec when i messed with that.
but im really hoping its the spc bolts.
Old 07-30-2013, 05:37 PM
  #106
Italianjoe1
Italianjoe1's Avatar
If those are "stripped", then every car has messed up adjustment bolts lol.
The lock-nut is doing the job of holding that washer to the car, not the center bolt's flat spot. The flat is to allow you to pivot washer with the bolt against the considerable resistance, but to expect a perfect snug fit there isn't realistic. As long as the adjustment is held accurately while the lock nut is tightened to spec and the result is the proper spec, the washer is fine. The center hole could be round, it would just be very difficult to make adjustments, pry-bars and such like an old truck, but the end result would be the same assuming the person doing the work is accurate.
Old 07-30-2013, 07:34 PM
  #107
ronn1
ronn1's Avatar
rear toe would be the FIRST THING I would look at. Hell..just put on stock toe bolts and MAX them to see what it feels like. You should be able to come close to spec unless the car is slammed. I have rear lowered 1 1/2 and stock bolts brought it just into spec. Car is ROCK SOLID and handles like a dream.
Old 07-30-2013, 07:40 PM
  #108
Bmurray350z
yeah i have no clue what happened to my stock toe bolts... gonna pick up a new set of spc bolts and see how that feels, then may try some stock bolts.
Old 07-31-2013, 02:30 PM
  #109
2004Black350z
Exhaust Whore
2004Black350z's Avatar
He found his problem...
Old 07-31-2013, 06:15 PM
  #110
Bmurray350z
nope.. thought that was maybe it but was not..
jay do you have your stock toe bolts by chance?
Old 08-01-2013, 12:43 PM
  #111
Bmurray350z
Okay.. New bolts are on. Here are comparison pics.
Pass side NEW bolts/washers on top:
Pass side NEW washers on right:
Drivers side NEW bolts/washers on right:
Drivers side NEW washers on right:
Old 08-01-2013, 02:27 PM
  #112
Bmurray350z
Well pretty sure I found the problem. Look how terrible my drivers side wheel bearing is
Old 08-01-2013, 03:50 PM
  #113
tbruner
tbruner's Avatar
Bingo!
Old 08-01-2013, 06:16 PM
  #114
labelworkshop75
Yahtzee. Glad you figured it out. Sorry I was not correct regarding the toe bolts, but your old ones are a bit fudged. I would go toe arms when you can.
Old 08-01-2013, 06:44 PM
  #115
Ak48z
Ak48z's Avatar
You going to tackle this yourself? I wish I just didn't pay the dealer $800 to replace that.
Old 08-01-2013, 06:47 PM
  #116
Bmurray350z
yep so you owe me $50 lol j/k
yep. got the hub and bearing pulled out in 45 minutes tonight. crazy easy. picking the new assembly up tomorrow morning. ($72 Timken unit with a 1 year warranty from Autozone)
Old 08-01-2013, 07:43 PM
  #117
Italianjoe1
Very nice, although that should have been found during one of the alignments, you cannot get a car to hold alignment if the bearings are that shot lol.
Miles on the car? I had to have my left rear replaced under warranty, less than 30K on the car IIRC. Seems to be a very common failure, usually on the same side.
Old 08-01-2013, 08:15 PM
  #118
Bmurray350z
60k miles. Yeah idk how the guy didn't find it... and i've never dealt with faulty wheel bearings so not really sure what type of sound to look for.
glad i figured it out though.
Old 08-01-2013, 09:15 PM
  #119
Italianjoe1
My car has kinda loud exhaust so I wasn't clearly hearing the normal humming bearing sounds, but I was noticing some weird noises when releasing the e-brake and turning, made me investigate and found it very sloppy, worse than yours. At least mine was free to replace. Although they didn't do a very nice job and left me with an axle click that I had to fix lol.
Old 08-02-2013, 12:58 PM
  #120
Bmurray350z
Replaced the wheel bearing (super easy for anyone who might run into this problem... 45 min to take the bearing off, 45 min to put it on), took her to get aligned, problem is officially fixed!
Quick Reply: Car feels extremely unstable going in a straight line
