Passenger Door window wiring harness
on
Hello.
I have a 2003 Nissan 350Z.
I was taking off the door panel to remove the old window motor for replacement and unfortunately when removing the wiring harness plug I accidentally dismantled the plug.
Please see pics below.
If anyone has the same wiring harness.
Could you please take a picture of the top and both sides of your harness and post the pics so I can re-assemble my wiring harness off of the color coding.
Thank you all.
Thank you all.
lol damn. idk the color order but I believe you need to remove the plug completely and pop it back together with the other half. then when ur ready jus slide the wire in the slots individually and they should jus click right in
on
Extreme bad luck.
I just ordered a new wiring harness on ebay and someone stole the UPS package from outside my front door. Now I need to order another one.
Could you please take a picture of the top and both sides of your harness and post the pics so I can re-assemble my wiring harness off of the color coding. That would be a huge help while I am waiting for the 2nd wiring harness.
So much for saving money to fix the window motor myself.
Thank you to all and everyone for any help. Much thanks.
I'm replacing my driver side motor this weekend most likely tomorrow. I have an 03 g coupe tho. Not sure if its the same.but most likely. I'll take a pic n post for u.
on
Same Problem
Hey was just curious if that configuration worked for you. I did the same damn thing trying to install some new speakers in the door and managed to pull all the damn wires out.
I am in desperate need of help lol.
Let me know if those pics of the drivers side worked or if its different for the passenger side.
350Z_Al
10-29-2020 07:44 PM
