Damaged quarter panel. Is this rust??
Old 06-27-2014, 02:09 PM
radiocrash
radiocrash's Avatar
Originally Posted by saywat?
Touch up paint has clear. Why wouldnt it help? None of my touch up paints jobs have failed me.
I could be wrong. I just always assumed for anything larger than a very small nick, touch up paint wouldn't cut it. That and it can easily look bad if you don't know what you're doing.
Old 06-27-2014, 02:20 PM
saywat?
saywat?'s Avatar
touchup paint Is mainly used to prevent stuff like rust and paint chipping from damages. its never going to blend perfectly and will always be visible. if that bothers the owner the only way is to get the entire part repainted which is costly. that is why u use factory touchup paint as an alternative. the larger the cover up the more noticeable itll be. that's jus life lol.
Old 06-27-2014, 03:30 PM
Spike100
Spike100's Avatar
The OP’s description sounds like surface rust. Surface rust is easily repaired unless it’s penetrated the metal (at least 5mm).
The big problem is internal rust. That is rust that starts from the inside (example is a fender well) and penetrates to a “bubble” on the fender’s surface. I’ve dealt with this, and it’s the worst case scenario. The only fix that works is cutting out the metal and replacement (very expensive).
AbrasiveRaysive
09-20-2021 02:29 PM
issyz
07-02-2017 03:04 PM
SpartanZ32
10-22-2015 09:36 AM
Cashwin
10-01-2015 06:36 AM
Quick Reply: Damaged quarter panel. Is this rust??
