right side turn signals/hazards, headlight wires
So about 3 weeks ago my right turn signal stopped working along with my hazards in my 03 350z, which was random, i tried to find the relay/flaser but no luck any idea? Also i was changing my headlights today and found that the wired that connect to the headlight(in the black wire tube thing) and realized that i not only had no cover for the back of the lights(the gray thing you twist and pull off to access the bulbs) but that the wires that i mentioned earlier has been rubbing against my tire(no fender protectors), and now it has a complete flat side instead of circle and wires are showing, could this be the cause of my turn signals/lights not working? Its ONLY the right side
im new to this forum and idk how to start a chat or w.e its called cuz i have a lot of questions about my Z33 i just got it and its my first car ever. well my question is what kind of oil should i use for the brakes, radiator, and what kind of liquid goes into my car. i also have a leaking issue in the front windshield pillar right side top and bottom its rotting also the body side molding weatherstrip on the right side as well is leaking. also im sorry this has nothing to do with your question.
To the original poster...........I suspect your entire lighting problem is the result of not having the fender liner in place. You probably need to get your car to a mechanic who understands electricity and have him fix your car. Then you need to get the gray cap and get the fender liners in place. After that, your car will be fairly waterproof underneath and you won't have wires rubbing on your tires.
Anyone have an extra blue connector to the right headlight with some wire left? mine for some reason broke off or got ripped off. As if it got disconnected and dragged on the floor and burned off. Thanks.
CFAUVEL
10-01-2015 03:20 PM
