A/C Not working, it's effing hot in KS please HELP!!! :dunno:
Hey guys how's everyone doing, well this past 4th of july weekend I drove off to MN, and on the way there I noticed on my gauges that the outside temperature went crazy, it started reading from 36F to -17F and it went up and down gradually until it finally read "---- ICY", when I woke up next morning tried turning the A/C on then I didn't hear the compressor kick in, it still blows air but no cold air, I read about the outside ambient temperature sensor might mess up the reading and make the HVAC think that is cold outside and not make the compressor work, I would really appreciate the help if any of you have encountered this problem, it's hot in kansas and wearing acu's all day doesn't really help, thanks in advance!
i think you already answered your question.. change the sensor and see what happens. it seems pretty obvious its a temperature sensor messing up if your gauges are reading way off. and it seems likely if it read 33 F it would not kick the compressor on because it would more than likely turn your compressor into an icepop.
on
I don't think the ambient temp sensor would cause the A/C not to work unless you use the "auto" function. Even then, it should be measuring cabin temperature, not ambient temperature.
I too would guess you have a leak in the system. Check and see if you have any pressure in the system.
08-06-2021 06:19 AM
11-09-2020 10:27 AM
